Solution to make glossy paint flat?
I have a ww2 damaged house diorama that was painted by my friend to look weathered a long time ago. I found my house again but noticed she used gloss paint. Don’t remember the type of paint used but want to know what flat clear coat spray can that can be recommended to make it flat? Would hair spray work as well?
Hair spray ‘may’ mat it out, but would be a dust magnet.
A mat acrylic clear spray should do the job, some people use Klear/Future with 2%-5% Tamiya XF22 added to get the glossy Future/Klear to mat out.
Other mat acrylics are available, depends on what you can get locally.
Will you be airbrushing or using a rattle-can ? For airbrush I like the Testors Laquer Flat or Vallejo Acrylic Resin Flat.
Also for what it’s worth,the Painting Section of the forum would be more appropiate and help you to get more looks and answers
Tojo, I’ ve been told not to paint laquer over any other kind of paint ie. acrylic or enamel so I am afraid to try Testors Laquer as a final coat. How do you get away with it ?.
I can’t say,I mean I have been airbrushing it for years,I never had it do anything to the paint I spray it over.I have used it over Tamiya and Modelmaster Enamels.The only thing I have noticed that it is not compatible with an enamel weathering wash or filter over it,But as a final coat,no problems here.
Anthony C
TY Anthony C, That’s good to know since the Testors is readily availble here but I have been hesitant to try it. Saves me shippiing costs on other brands I’ve been using.
Well you know nothing is ever absolute,so I would say to experiment 1st to be sure
Thanks. I plan on using rattle can.
I have heard of people using Krylon
Krylon clearcoats works good for me. Try that instead.
My go-to ordinarily is Testors Glosscoat. I have used it successfully on both enamels and acrylics. I have also used Polyurethane clear, which comes in gloss, flat, and semi-matt.
TeeJay,
I exclusively use Model Master dullcote in the rattle cans. I’ve never had any issues with it reacting with the underlying paint (I use MM and Floquil enamels as well as PolyScale acrylics).
As others have mentioned here, test it out first on a very small area of the diorama just to make sure that there’s no adverse reaction especially if you’re not sure of what kind of paint she used.
Eric
I second using Testor’s DullCote in rattlecans. I use it, haven’t had any problems with it.
The only caution I can think of in your scenario is that if you have any clear parts that you want to remain clear, like windows, you should mask them before spraying. The matte coat can frost them. But that might not be an issue for the diorama you describe.
Hope that helps, best regards,
Brad
