Snaps epic Journey - Airfix 1/24 Hawker Typhoon Mk1b build
Let’s start off in November 2013 when the test shots of this were revealed at Telford to a very exited model building community. At the same time, Across the Isle from the Airfix stand was the Zoukei-Mura stand, Also announcing their 1/32 Horten 229 Flying wing. This area of the model show was crammed full all weekend with modellers and the sound of shutters and flashes of cameras and iPhones was deafening and blinding. Moving on to July 2014 and after a long wait and a delay we finally have the Tiffy - and what a kit it is! I think that you could safely say that it is a 1/32 kit but in 1/24 scale. For a 1/24 kit, the part count is off the scale and there is so much detail the build instructions, far from being Airfix’s standard fare is actually a book of CAD drawings on decent quality paper. There are 3 display options and markings for 4 aircraft and alternate parts galore. I would say immediately - DON’T JUMP IN RTFM first… and more than once. get the icons memorised and also read the small print (in your chosen language) otherwise you will miss some important information that could lead to much frustration and the swear jar being filled at an extortionate rate. Airfix have a good idea here of showing parts, where they go and then showing them in place coloured red, often in separate drawings. Also there is a tendency for stages (there are over 200 stages) to be crammed together. They are not like the dragon instructions though that can lead builders astray and often banging their head on a desk and crying, but are divided up noticeably. Some sections also have alternatives too. THIS IS WHY YOU HAVE TO READ THE ENTIRE BOOK and understand exactly what you have to do, which display option you are doing AND which aircraft! There is as much detail in the instruction book as there is in the kit and it can sometimes distract to how parts fit. No matter, those of us who will get and build this beast will spend lots of time with source material, photos etc. as well as many dry fits so we know just how things go and we don’t muck up. Muckups will be done, but I reckon that it will be the builders misunderstanding on what actually fits where, and what to! The designer himself (Who in my opinion should be given a raise and many congratulations) himself put 5 test shots together just to make sure it is right and goes together properly. That’s dedication! Any muckups are the modeller!!! In the manual - sorry, book - there are no sprue diagrams and no paint list. There are numerous paint call outs for parts but nothing to refer to, until the exterior paint and markings for the 4 aircraft covered on the decal sheet. This in a kit of this size and complexity is a failing by airfix, and no suprising that any paint numbers are humbol colours only. Get your colour charts and matches out guys! There is a complete list of paints for each aircraft covered on their website BUT NOT IN THE MANUAL. Airfix, this along with sprue diagrams need adding to the build book. On to the decals. It is a large sheet and printed by Cartograf in Italy. No worries there then. I have noticed that apart from the two code letters for the squadron there is very little to no carrier film around the decals. The only reason for carrier film to be between the two squadron code letters is to provide the correct spacing. All the exterior decals look to be right in register and the correct size. There are lots of stencils including bomb and two types of rocket stencils. There are also individual dial decals for the instrument panel, but I think that Airscale might have the edge on these when they release their tiffy cockpit set including placards and bezels. A very nice set of decals to work with. On to the parts themselves. Now let me say right away. You will find the odd bit of flash. BUT - and it is a LARGE BUT - What you think is flash could also be part of the part itself. Also there are stressed metal areas moulded in to the fuselage, wing and control surfaces. There are also raised detail and flush detail next to each other, overlapping etc. should you feel a bump under your fingers then don’t reach for the sanding stick. IT IS MEANT TO BE THERE!!! There is detail galore everywhere you look even down to separate seatbelts. I have photographed every single sprue and done close ups so you can get an idea on just how incredibly detailed this Tiffy is! Don’t take that ridge off (below) at the top. It’s the bubble canopy runner (both parts) On to the clear parts. They are very clear parts and well done. There are a couple of items to note. On the above sprue what looks like wing landing lights and bulbs are not used. They have a cross through them in the instruction book for this kit. They will probably be used for the early car door one. Instead there is a coloured part to use in their place. The canopy sprue. Very clear, but several people have noted a slight lens type of effect in a small area of the canopy. I tried to photograph it but wasn’t successful. You only notice it if you are looking for it. As the bubble hood is not supported properly on the sprue a stress fracture has appeared on the canopy. It is only a small one, but Airfix should have looked closely at this and realised what could happed and made the necessary adjustment. Never mind. What done is done, and really I won’t bother me as again you will only see it if you are looking for it! A bit of flash? probably, but also you can see where the canopy runner goes through. As noted above - DON’T TAKE THAT OFF! Poseable control surfaces. An engine that is more than a kit in itself ( I am sure, that despite the instructions someone will come up with a way to display this Napier Sabre in all it’s glory, pipework and everything on it’s own stand next to the aircraft). Internal structure, wing and leading edge fuel tanks, weighted tires, full set of ordnance, two types of rockets, 500lb, 1000lb bombs, external fuel tanks plus racks… Mk1 & Mk2 rocket rails… so much in this kit to keep the modeller occupied for ages. I can see some modellers buying more than one and a few being entered for Telford in November! You thought the Mossie was good? This is even better! There will be some that will turn their noses up, not for me, not my scale, not interested etc. etc. One thing I will say to them. Never mind the price. Never mind the excuses. Get yourself this kit which probably is the turning point in 1/24 kits. Enjoy the experience of what this kit will give you. For those who make this kit (Hi trumpeter) you have better learn what we want in this scale, because Airfix just provided it! AIrfix… you get 11 out of 10 from me for this. No kit is perfect, and I have to really niggle to find something, and that is that the cannon barrels look a little soft… However my set of Master 1/24 barrels should cure that! James
Good night! Epic journey is right! Wow! That is one detailed kit! It will be awesome when done, but you might as well build the real thing! [;)] Can’t wait to see this build!
Eagle90
Here is the start of the build folks.
First of all, as I had speculated on Master models’ 20mm Hispano Mk II cannon barrels with a total of £16.50 then that is the first place to have a play before starting on the cockpit area. The Airfix barrels are indeed wrong
Something had been niggling me about the 20mm cannons in this kit and once I had taken one off the sprue and then compared it to the Master barrels it hit me. The airfix kit cannon has the springs in the wrong place and the cannon are about 2mm short in the barrel. Take a look! Airfix’s Hispano 20mm Mk II Part of the fairing - well, half actually! Airfix’s cannon and fairing together. See how it fits. Master models barrel matched up to Airfix’s barrel. Hmmmm! I do know from photos that the 20mm cannon muzzle did protrude from the fairing, and the MM barrels seem to do it by the right amount! All I have to do is to bore out the interior of the faring a little more so that the recoil spring sits properly.
First of all let’s stay with the cannon for just a few moments. Airfix have provided the cannon fairings as two separate halves. Be warned builders. Although they all look the same, (top halves and bottom halves) they are ALL different. There are port and starboard, inner and outer top and bottom halves. DON’T GET THEM MIXED UP. When it comes time to fix them, do them one at a time! Now with the fairings being separate from the wing and each half dedicated to a cannon port this can give the builder the option of putting them on, or not! Advanced builders eyes are now rolling to the back of their heads as they slowly begin to see what just can be done with this kit. Like I said - more to this than meets the eye. Now we all know by now that the Airfix 20mm Hispano is not very accurate in regards to the barrel. They do note in the instructions that you can, if your eyes can see to do it drill, very carefully a 0.9mm hole in the muzzle to provide us with the bore. In this aspect, if you do the math then Airfix has got the bore right for 1/24 scale. :smiley: However they got the recoil spring in the wrong place. I don’t know if it was to make the faring fit the cannon or what, but purists who want to leave off a faring or two will have to correct this. Going back to my post on the cannon and Master models 20mm barrel, I have done some building and correction. Here’s a reminder of Airfix’s 20mm Here’s my rebuild using master’s 20mm barrel and fitting the ammo feed. It’s ready for priming and painting. Now it has been noted that there will have to be alterations to the apatures in the wing frames to fit this. They would have to be done anyway as the original Airfix cannon when built wouldn’t go though. It is and easy change as the holes just need enlarging. Now if we are going to alter all 4 cannon and make them right then there is another alteration to be made and that is to the fairings interior. they will have to be filed or sanded from the inside until the barrel fits properly. Airfix plastic is relatively soft and plyable so it’s not too difficult to do. Just sand, clean, dry fit… and do it while it looks right and the fairings for that port fit properly. It is correct to have the front 2 or 3mm of the muzzle sticking out. The cannon I have rebuilt is for the starboard inner gunport. Each gun and feed is for a different position. Take care when building and do one at a time. Next post we discover the delights of the cockpit area and I fall into a trap of my own making! James
Here we go with stages 1-8 The cockpit frame. I spent quite a lot of time with the instruction book working out the best way to put these parts together. I did this and the only part which I left off was the footboards which can be fitted at the end of stage 8 with no problems at all. Here we are with the build of the cockpit and engine support frame, unpainted and with out the footboards. It looks good. Plenty of fine detail. Problems being seam lines, some flash and because airfix uses quite soft plastic, some warpage. There are also mould release markings to be dealt with if you are going to want to do surgery to the fuselage to display this. The warpage is easily dealt with due to the soft plastic and occurs mainly with the wing spars. Only then did I think about painting and I decided to go partly my own way with this and putting on the primer coat of black showed me that this wasn’t going to be easy to paint and I eventually realised that I should have painted each piece individually and then once together touched up with a brush. This is a note for my next Tiffy! The frame in Primer black. I did this in black so that the aluminium and interior green paint would show up better and have a good dark base rather than a neutral grey. I decided that quite a lot of the forward airframe, especially in the engine bay would be interior green. Having original BS reference paints, but not used that brand before through my airbrush and no empty dropper bottle to decant the extracrylix paint into, I referred back to my own paint matching charts. The closest Vallejo paint for interior green is 71.126 IDF Green. It is only a fraction lighter than BS283 and with a dark primer underneath it should come out just about right. It wasn’t easy to airbrush everything when together and I had to redo areas that had suffered overspray and ended up with a touch up session with a paint brush, still I am pretty happy with the result, and I think that it looks close to what a wartime Tiffy would look like. After looking at cockpit photos on the net, my next tiffy’s airframe will look slightly different. More Aluminium, less black on the frame. Once dry and cured I added the pre-painted footboards. Next up we start adding detail to this area! Comments etc welcome
This looks like a fantastic kit to work with and credit to Airfix for getting all that sweet surface detail molded in.
Have fun with the build and please keep us posted in this WIP- I am just jealous enough to consider getting one of these myself.
Off to a nice start. That kit looks amazing!
Looks awesome. I have been intrigued by this kit, so will be riding alongside your build. Thank you for sharing; it has already been informative.
James
Great work so far. I got a reply from Airfix and they will replace the canopy if you drop them a line. Below is a picture I’ve taken of the “lens” on top of a mesh so you can see it a little getter
I agree with the comments on the Hispano cannons, it will take a little work but be worth it. You can also get some aftermarket belts from RB Productions they are the Suttons QS/QL/QP harness.
Looking forward to the rest of your build
Phil
This is the email I received today from Airfix
We are very sorry you have experienced problems with the product A19002.
The problem with the Q sprue, is not common to all the kits.
Problem was only found after the mould inspection when the clear sprue had been standing for several days.
The sprue feed was changed to eliminate this problem.
Would seem that some incorrect parts have slipped through.
We have despatched the Q sprue for you today.
Once again sorry for any inconvenience caused.
Regards
Airfix spares.
I wouldn’t say thats a bit of “smoke” as I’ve heard for 4 kits now with them all having the issue, but as long as they have fixed the issue it may solve the issue with the split James had. I’m not sure how it could take several days for the issue to show, does it take days for the styrene to cure? I may have learnt something here about the manufacturing process.
Phil
Ah! now we have a little admission of guilt from airfix. Looking at it objectively it doesn’t really detract from the overall kit, but it shows a little about their production.
I am assuming that they had it moulded in China and not by trumpeter who was rumoured to have moulded the mossie for them.
I do watch a lot of “How it’s made” TV programmes and so learn a lot about manufacturing.
Yes, there is a problem with the sprue Q mould. It was probably fixed as soon as it turned up. If the sprue feed, where the liquid hot plastic was not quite right then this would cause problems as the plastic injected into the mould would not have got to everywhere it should properly. This in turn would cause the lens effect as the plastic would not have formed into that part of the mould properly.
This would have a knock on effect to where the part meets the sprue and the connection made there. All the bouncing and movement involved with packing and transport could cause undue movement there on the canopy part as it is the only bit of the part that attaches to the sprue and could cause the stress crack.
There could have been a lot of kits packed before this problem was highlighted and fixed. This is why airfix probably have a lot of corrected sprue Q’s ready for customers who complain about this.
I am not sure how long it takes styrene to cure though. I think it’s a bit of truth, smoke and a couple of mirrors.
Still, despite this and the incorrect 20mm barrel I am so happy that at last the 1/24 kit has come of age with detail to rival 1/32 kits at last!
Despite a couple of drawbacks, flash and seam moulds etc (of which most, if not all kits are guilty of in some way) Airfix have done us proud. 11 out of 10 and a lot of brownie points.
Now let’s have the car door version and then a ME-262!
Thanks for critique on this great kit guys!
My kit arrived from UK yesterday, wasn’t expecting this until end Aug?
After reading this thread I delved into the box searching for the clear parts to inspect for the small issues noted.
Well, I can’t find the Q sprue!!!
Now I see the relevance of the missing sprue digram - what else am I missing?
I’m on to my supplier now…
NeedBeer
Check for a two small bags with what looks like paper towels inside, there should be two of them and they are about 5-6 inches square.
Phil
So the replacement arrived, after one day which is great – problem is it has a “lens” in it too
So just about to send another message to Airfix and let them know. I wonder if I should mention FSM website and this thread, I wont as it would be unfair but they must know people have found this.
Phil
Believe me I’ve looked, opened the sealed bags, turned the kit upside down … It’s not there. Maybe they gave to you Mitch P???
I’ve contacted Hornby but have only had automated response. I did mention the forum, they need to know what their customers are talking about, besides this is an expensive kit
Ok just checked my email. Hornby have responded with same standard response re MP’s previous post re quality issue, don’t know if they read my email properly?
Anyway they Anticipate replacements arriving 4 August, I’m in no rush so wel’ll see what happens
I’ll have to admit that at first I wasn’t too excited about these new large scale models but after building the 1/32 Tamiya corsair and currently working on the 1/32 HK B-25 Mitchell I am having a change of heart, these things are pretty fun. But, the detail on this kit is beautiful. Great work. I will definitely be watching this build. John
My replacement Q sprue has exactly the same thing wrong. Also I have noticed that the windshield also has a lens issue.
(http://s353.photobucket.com/user/jamesgoddard_photos/media/Airfix%20Typhoon/DSC_0568a_zpse19e8c6a.jpg.html)]
(http://s353.photobucket.com/user/jamesgoddard_photos/media/Airfix%20Typhoon/DSC_0569a_zps072c7b65.jpg.html)]
I have also noted that the undercart legs D43 & D44 are not formed properly and (on my kit at least) you won’t get the wheels on
(http://s353.photobucket.com/user/jamesgoddard_photos/media/Airfix%20Typhoon/DSC_0562_zps2276efba.jpg.html)]
(http://s353.photobucket.com/user/jamesgoddard_photos/media/Airfix%20Typhoon/DSC_0563_zpsd381918f.jpg.html)]
You can clearly see where the correct line is and it is not too much extra work with a sharp 11 blade and some very, very fine (at least 1000 Grit) wet and dry to cure along with much test fitting. Still I can’t work out if it is a casting or mould problem!
Onto the build update.
I decided to have a slight change in tactics ( this is a big kit and with various sections you can jump around a bit, so I moved to tackle the Napier Sabre engine block and supercharger.
I had no real problems putting the engine block together. There is provision to put a small electric engine in so you can have the prop turn, but you will need to purchase a stand to put the model on and cut some extra holes in the fuselage bottom to accommodate the stand fixing and the cable for the electric motor.
Long ago I came to the inevitable conclusion that model kits that have electric devices in are inherently dangerous to me after managing to electecute myself more then once with a R/C Boat. Ever since I have stuck to static stuff.
During my search around the net I noticed the Sabre engine block and some attachments were a glossy green colour. Every picture I saw showed me the green engine block. Some wartime colour photos of Tiffys undergoing maintainance show the Sabre engine as a dark colour, but to be fair these photos aren’t close enough to actually make colours out in the engine bay as they are taken from a distance. Also these photos could have been colourised after the fact.
My first paint job which I didn’t photo used Vallejo Model Air Pale Green 71095. After sitting for a while and looking at what was a good impression of a deformed Granny Smith Green Apple I rummaged around my paint stand and after some thought give it a coat of VMA Panzer Olive Green 1943. This gave the engine block and supercharger parts a much better and closer colour to the ones I have seen on the net.
(http://s353.photobucket.com/user/jamesgoddard_photos/media/Airfix%20Typhoon/Build/sections%2039-48/DSC_0564_zps13455467.jpg.html)]
At this moment I am suffering from a problem that has stopped me taking photos until I can sort a claim out and get a new lens.
My Nephew accidentally knocked my best Nikon pro lens (£1500 quids worth!) onto the floor and while it takes photos, the zoom function etc is very wonky and the auto focus isn’t very auto any more and the manual focus just doesn’t work.
I am trying to do a work around at the moment.
Stay tuned for more adventures from the bench!
James
James
I;ve not noticed an issue with the landing gear, I’ll have a look later just so we can confirm if its a general issue or just yours. I am half hoping to see some after market items come out as I’m syill not sure the Airfix ones will take the weight.
I’ve noticed in the past a lot of engines blocks from that time where a deep green but not many paint charts show that, I did wonder a couple of times if it was a restorer getting it wrong
Your build is looking good, you may be the first perosn to finish a production run kit the way your going
Phil
