Hi Chaps!
Once again my bench recieved a quick clean with a sweep of my arm into a box with a muttered "Sort that lot out later and a large pile of grey plastic hit the bench.
I won’t bore you with an OOB review, you can all see the sprues etc on Tamiyas website and elsewhere around the net. except to say that the detail and fit of this bird is the best I have ever seen and I wish ALL kit producers would gives us this level of detail and quality all the time!
A necessary trip to the little boys room (due to tablets) and with the build manual produced a longer stay than needed and help was required after my legs had gone numb and there was a large red ring around… well I think you get the idea!
I was going to use the rub n buff system to do the metal exterior as I don’t use an airbrush but after much thought I purshased Tamiyas AS12 spray tin. Please don’t laugh as it is my first time using this stuff!.
On we go.
Forgoing the manual which starts with the engine I started with the cockpit and my paints. A mixture of Vallejo and tamiya soon saw parts start to take life on with the colours of Interior Green, Black, Olive Drab, Chrome Silver, Red & Yellow.
As I worked I saw that despite tamiya including a few decals for the cockpit and some seatbelts in etched metal apart from the paintwork in various colours the cockpit does look bare despite all the detail that tamiya has moulded to various parts and and the parts you add in yourself during the building progress.
As THis is going to be displayed in a friends restaurant for a month or so after being finished and with it being so new there is more or less nothing in the way of after parts for this kit then I turned to airscale and bought a set of their placards to use to busy up their cockpit. These arrived this morning and do look really good.
Below is a series of photos of the cockpit and how it goes together. At the moment everything is dry fit but ready to be glued when I have placed extra placards from the sirscale set and also painted and built the seatbelts.
There are still some parts to be added before the cockpit goes together properly, but I thought members would like to see how the tub etc goes together.
The instrument panel put together and after a couple of extra placards to go on ready to be glued in place
The instrument panel top cover with the gyro gunsight in place. Just a decal from Tamiyas’ stencil sheet to apply. The gunsight is a small item and needs concentration to build up and paint. A etched metal part is used and care must be applied to avoid fogging up the clear plastic used.
The basic cockpit tub. This is painted up as Tamiya suggest with vallejo and Tamiya paints. There are still parts and manybe a placard to add, but the stick is in place.
The radio and battery parts along with their frame. All this bit is glued up and painted and just needs a couple of placards before adding to the top of the fuel tanks
The seat. About seven parts, etched parts,paint and decals here. I have yet to make, paint and attach the etched seatbelts to the seat before adding the back to the seat and installing to the base of the tub.
The front section of the cockpit where the instrument panel and top cover/gunsight attach. The rudder pedals already attached in place and painted.
All together - this is a dry fit
The seat and armoured back panel together, this is a dry fit and the seatbelts have yet to be added, as well as some extra paint detailing.
Here we see the radio and battery panel on top of the fuel tanks.
The seat added
All together. This is a dry fit and shows you just how close tamiya have got the tolerences for fixing… when it is together you can’t see the joint… and if there is one just a little extra paint will hide it.
All I have to do here is add some placards, do the seatbelts and add a couple more parts and it is ready to go into the fuselage!
Comments welcome
James
