No pics in this update, but I will post some tomorrow. I just wanted to let you all know where I was in the build.
The cockpit is finished and ready for installation. Unless I missed something then I have found no MG magazine storage in the cockpit area, unless it goes in later.
I am currently working on the radio op/ navigators section behind the bomb bay in the fuselage. I think that there are some parts missing from the instructions here.
Section 13 - window transparancies are all there, but take note of the numbers and use them as there are left and right ones here. No problems with the fit, but take care with glue.
Section 14 - more transparancies - same as section 13!
Section 15 - Bulkhead fitting. No worries here at all. Match the notches up and glue!
Section 16 - I am building this up in 2 parts. These are the MG gun magazine stowage and it has you fitting the MG magazines to the stowage parts. I will actually fit the stowage racks first to the interior and then the MG magazines.
Section 17 - This is where I encounter a head scraching problem. The instructions tell you to mount the floor of the compartment between the middle and aft bulkhead. No problem there at all great fit really. It also has you fitting one - or possibly two MG racks to the floor - I am not sure how many. The problem is that the holes on part 300 (floor panel) don’t fit the MG Magazine rack nor is there any holes on the other side for a MG rack to fit.
Now then, for those who have this kit, there are holes in the left hand fuselage side (part 123) next to the aft window and forward of the next window to that that match the pins for the MG magazine racks perfectly. Also on part 297 (Section 18) the holes for the MG rack indicated on the instructions are too close together for an MG rack placement, also trying to place the rack where indicated will foul up and prevent the mounting board for the radios being correctly fixed in place.
I have consulted the instruction book in my inner sanctum of peace, and just before my legs became numb from sitting on the Great White Porcelain Throne and having to call for help I came to a decision.
Two racks would go on the walls next to the windows as the pins fitted perfectly and there is nothing in the instructions about putting anything in those areas at all. They could be for a future different version though!
Any MG racks that needed to go on the floor could use one of the locating pins and holes with the other pin being removed to make secure fit. The last rack would go on the bench but using a hole that would not impait the radio board. That meant removng a pin from the racks. MG magazines will be painted and fitted before the fuselage is closed up. THe fuselage wall forward MG rack is right next to the radio board and looking at it the MG magazines may not fit properly so I may just leave that empty.
I am not quite so sure where some of this stuff is going! There seems to be holes in the wrong place, no holes at all or just misleading instructions. The parts fit together very very well though and although a little confused I am happy with my build to date.
I will admit though to taking a day or two to go up to the Yorkshire Dales on my Motorbike with an overnight bag to get away from the mass of plastic on my bench and to clear my head.
Overall, apart from a couple of head scratching moments listed above this is another stunner from Revell and those that decide to build this will not be disappointed. I do see potential think first act later moments up and coming such as the tail wheel and undercariage assemblies.
Regarding the bomb bays… Paint first, assemble later! with extreme care and tape!
Does anyone have the new Tamiya 1/32 P51 they don’t want?
Look out for Photos tomorrow
James
