Here we go with this build. This is only available in Germany, Austria and Italy. This means that as my knowledge of these languages is down to getting alcohol, food and an ambulance/Paramedic that Google Translate is my friend [^o)]
This is a weekly build and so far I have the first 8 weeks in my grubby paws. It is also quite expensive so I am NOT rushing the job.
The Majority of this build is in etched Brass and I think aluminium skin. It is possible to solder this together, but as that is not in my skill set I am using Cyroan-whatever - Superglue to me!
Here we go chaps.
Issue 1 - Hachettes Build A JU87 Stuka.
The Parts
The Build
Starting off With the cockpit area I put together the pilots seat rostrum. This will have to be painted RLM 66 and RLM 02. First of all the sides put on and my trusty square to make sure that it is at 90 degrees.
Both sides on. My square used to make both sit properly upright.
THe top part put on. THis is only dry fitted to make sure that it does fit correctly before the inside is painted RLM 02.
The first frame is a double one. Above you can see the inner parts of the frame bent to the right angle and curve and glued in place. I think that this is where one of the wing braces fits so I use my square again to make sure that the inner parts are at the corrsect square angle. The other part of the frame will be put on after the painting is done.
Interior base coat of RLM 02 applied. I will do another 2 thin coats to firm up the colour and to even out the paint. After that has dried I will assemble the parts together and then add the RLM 66 cockpit colour.
Done! all painted, assembled and fits just right. I have the instrument panel to do - but at the moment I will leave it while later. So issue 1 is complete apart from the instrument panel which will be done at a later time.
