Just curious what colour you guys use to simulate rubber parts like front fork seals, hand grips, etc.
I normallly use either Gunze Tire Black (H77) or Tamiya German Grey (XF63), not sure if other makers got a similar colour.
The recommended flat black I only use when I run out of those 2 colours.
Front fork seals & handgrips?, we must be talking bikes here!
Try doing a coat in black and then dry brush over it with a slightly lighter shade.
Rubber, especially on tyres (tires) doesn’t stay black too long, due to sunlight, dust etc, the lighter shade (black with a touch of light grey) will add depth to it, especially on convoluted fork seals.
All the best
Pete
What about using the plastic sheath from copper electrical wire, after having used a wire stripper to remove the copper? I’ve used it once or twice for general scratchbuilding for rubber hoses, etc. Hope this helps.
I read somewhere that a good way is to add blue to the black. I did it once on a set of small tires an it look pretty good. When I did that it also made it easy to do a wash and drybrush.
