I need some advice. I am currently constructing a WWI bird, a Sopwith Pup by Airfix. I am planning a small diorama with it taking off from the airfield. What options do I have in simulating a moving propeller? When I was a kid we used to use a clear plastic circle with some “prop blurr” painted on, any other options?
I’ve done the plastic disc with the “blur” done with liquid cement, as well as no prop at all, just took the blades off the hub and filed it smooth. Personally, I think the smooth hub looks better…
With the Pup, the second problem would be getting the engine to spin as well as the prop…
I’m thinking that it COULD be possible to simulate a spinning engine with puttying the jugs and some “blurry” painting of the pushrods… I’d suggest building a “Spinning engine and prop” for photos and keep the kit engine and prop for static display of the model after you get done photographing it… One could make a plaster mold of the engine front and then cast an engine to experiment with…
Or maybe you could make it a moving diorama. Order a small motor used to make pages and cell phones buzz and make the whole thing a battery operated deal. You would get a lot of “cool” points for that one!
There weren’t any when I first when to that website, but on return I have the red Xs, too. They are three bladed props in the pictures anyway, so they wouldn’t be of use for a WW I aircraft. I just thought that the site might be a good place for him to start. Perhaps a little surgery on the blades might work.
The PropBlurs are individual photoetch blades that can be trimmed to fit the desired length, so they could be used for a WW I aircraft. As to how to simulate the rotary engine part … I’m gonna stick to my 1/700 ships!
We have a winner…
Mustang doors slowly bleed off hydraulic pressure on the ground after shut-down. (This is on-purpose to extend the life of the seals, according to our chief wrench on “Gunfighter”) As soon as the engine starts, the doors come up…
