simulated wood grain
I know this has been posted and answered before, but can someone explain for me a convincing way to simulate wood grain…I’m doing some ladders and need some advice. Thanks.
drop-off;
You could solve the problem by using real wood if it is in scale to your project. If this will not work try this. With a razor-saw or hack-saw blade lightly drag the teeth down the length of the plastic, you will see little furrows cut into the plastic that look like wood grain pattern. Give the plastic a light sanding to smooth out the high spots of the “wood grain” and paint. You can add “knots” to areas with either a straight pin or a small dab of paint.
I hope this helps.
Cheers;
Gregory
