should I use a certain brand of model cement?
I grew up with tube squeezed model cement and have come to notice the many diffferent types of modeling cement. Is there any major difference between them all?
Tube or the container with the very fine tip? So many questions regarding model glue…and does it all have that strong citrus smell to it?[8-]
dude, dont use the orange tube stuff, its nasty. get some liquid stuff that comes witha brush. it works MUCH better
I grew up with those glues as well, but time passes and technology advances. As you well know, their joints are relatively weak and they take a while to dry. The best stuff going these days, IMO, is Tenax 7R followed closely by Ambroid Pro-Weld. These are both very thin, apply them with a small brush or a “Touch-N-Flow” applicator (I use a hypodermic needle with the point cut off) and the glue will wick itself into the joint. They actually melt the plastic, but unlike the old glues these are dry in a few seconds. Seams will virtually disappear since they get melted together.
The drawback to them is that the parts have to be touching. No putting glue on a part and then putting the parts together. For those situations, and for non-styrene gluing, I use cyanoacrylate glue (CA). I prefer the Zap brand, but other hobby-type CA’s are good to. Stay away from the general purpose “Super Glues” as they are not as good. CA’s come in several viscosities, ranging from thin to gel. I normally use Zap-A-Gap which is on the thick side and can be used to fill minor seams.
I tend to use Tamiya’s Extra thin cement and various Super glues / Epoxy as needed
hey
ive been using revell cement (with the 5cm metal tip) and have had good success with it…
the secret to good application tho is… donbt put the tip where u want the glue to go, instead place the applicator where u want glue about 1cm from the tip, then let the glue flow on by itself, geddit? u need to bring the tip close to where u want glue to get it going, then u just move it away a cm…
I use the testors liquid, but in the black “bottle” with the metal applicator for most standard glueing, but I just started using Tenax on any and all seams and joints I want some added strength. I don’t know how I got along without this stuff. Plus I have some CA for resin/PE stuff that I add from time to time. It definitely helps to have a variety of glues on hand.
I’m a big proponent of Ambroid pro weld…but, tenex is good too. I like liquid cement as the reasons stated above, whereas I’ll use a spot of tube for those situations where I need a part to stick before appling liquid - you only have so many hands.
A bottle of zap (medium for most jobs) CA is a good thing - for PE, you definately want slow set so you can move them around a bit to get the correct position.
I’m definitely an Ambroids fan… newly converted as well… I was using the tube, the switched to the metal applicator tube like Model Masters… then I tried Ambroids and there’s no going back!!!
I’ve heard the same stories about Tenax but I haven’t tried it yet… you just hold the two pieces together, with a caillary pen or a brush go down the seam and 10 seconds later Bingo!! You’re welded shut… good thing is (unless you get your finger on it [V]) the excess bonder just evaporates away like there was nothing there! (if you get your finger on it expect a nice sanding session as it works faster than the tube stuff)
CA for PE, just like everyone else said…
I only use two…Tenax 7R and Zap-A-Gap CA
Thanks for all of your responses… seems as though Tenax 7R and Zap A Gap CA are the most commonly used glues. Not a whole lot of modeling experience here so I shall purchase a couple of cheap kits to mangle before I begin work on the real beauties.
Just purchased the George Bush TBM Avenger and the Midway Dauntless divebomber.
Sweet… and very detailed[8-]
brother, just get what ya like… and happy modelling to ya!!! I think once you use something like Tenax or Ambroids you wont go back except int the cases mentioned already… (not enough hands to hold the pieces etc…) it tickeled me me pink the first time I used Ambroids…
good luck to ya!!!
I like the pro-weld glue for most of my modeling… but also use super glue in places.
wow these glues sound unreal!!
im gonna go check out my lhs’s 2moz
so any excess just dries up hey? awesome…
ive just discovered the capilliary action powers of tamiya extra thin cement and cant wait to get my hands on some of this stuff…
so is tenax and ambroid pretty much the same?
hey i dont think im gonna b able to find tenax or ambroid here in sydney…
can anyoine reccomend something similar?
thanks!
Ambroid has several different kinds of glue. The ProWeld (I think that’s what it’s called) is very similar to Tenax. I have both kinds and really can’t tell much difference between them. Tenax might dry slightly faster though.
I’ve heard several meople mention Tamiya Extra Thin Cement, and I wonder if it’s about the same. I suspect that it is but haven’t used it myself.
i havent used tenex nor ambroids nor tamiya super thin cement, but i dont think they are the same or similar products, though they do indeed behave in a similar manner
FSM had an article on mixing your own liquid cements (tenex, ambroid, tamiya, testors ad nauseum use the same chemicals I think) a couple of months back.
nah i dont think they could use the same chems coz i have tamiya cement, temiya ex thin and revell contacta and i feel that those 3 behave pretty much the same (ofcourse that tamiya ex thin is thinner!!!), but they dont act nothing like what i heard that tenax does… any excess with these 3 does not evaporate and they take longer than the short time that ive heard tenax takes to cure…
From what I’ve heard a few people say there’s some good hobby shops down under, you should at least be able to find it mail order somewhere in Australia… if not at your LHS… the one near me has it in a very unnoticable place… I didn’t spot it till I knocked a kit off the shelf when I was bending down I noticed it on like the 3rd shelf down… ask, you might be surprised!
hehehe
i went 2 one lhs and asked and i all got was a strange look…
went to the 2nd one and the guy there showed me this other stuff and he was tellin me that all glues r pretty much the same, just different thicknesses… so maybe tenax is thinned differently than other glues? he showed me 2 glues, both of which he said acted closely to tenax. i got one which is called plastruct plastic weld. on the back it says bonds in minutes and solvent evaporates quickly… ill see how it works out…
