I’m curious about how individual ship planking has been installed by some of you out there. Ive read little tid bits about it on this forum but nothing really specific. I’d like to know what kind of planking was used and where did you get it? I would use nothing else but contact cement to put it down on the surface-eould you agree?Was it balsa? Did you stain it and individually put peg/nail indentations in it?Did you apply any blackening to simulate tar/caulking? How did it turn out and would you do it again? I want to try and do this on a Revell Spanish Galleon.Gmorrison where did you go? Can’t find you anywhere about Heller Victory parts.Thanks,Mark
Hi Mark,
Haven’t been down to the PO in a bit, but I’ll let you know.
Never use balsa, unless it needs to fly.
Good planking choices include basswood, which is available in all kinds of sizes.
I have a little table saw, so I can choose other species. I like to use holly.
I glue it down to plastic with CA, or to wood with white glue. Contact cement sounds like a reasonable way to go.
I’ve tried to blacken the edges of the planks to look like caulk, but couldn’t get acceptable results. I’d guess it’s a better idea at larger scales.
Thanks Bill, Sorry I lost you somewhere and couldn’t figure out where.There is absolutely no hurry what so ever on this-(havent even started on it yet) just didn’t want to loose you in the"abyss".Thanks for the plank response, I/ we love your responses on your experience with these ships. I suppose HiSmodel or Syren or others would have plank material appropriate for this,just wanted to see if other modelers were successful with this approach as opposed to buying pre made deck material or pre made full printed ones. Mark
Sure, you got it.
I’d be surprised if there’s a deck made for that model, but I could be wrong.
I don’t know a thing about Galleon decking, but it was probably fairly wide. For simplicity sake, since the model is 1/96, a 1/8" wide strip would be a foot. I think that would look pretty good.
I think planking decks is fun. It’ll be a big plus on your Victory, even just the weather deck. This is a good place to practice.
You can buy basswood from Blue Jacket or probably Model Expo. The general principle is that the planks start and stop on cross beams, and the cross beams occur at the frames, so it all has to line up. The frames are where the gun ports “aren’t”, they bracket them. So take the plastic deck and accurately draw a centerline down the middle. The make evenly spaced lines side to side where your deck beams would be. A guess would be on four foot centers, which is 1/2" to you. Draw those lines across the deck, starting from the bow to the stern.
I start planking in the middle. Ships typically had a wider plank down the center, a king plank. I think you can ignore that here. Lay planks along one side of the centerline. There’ll be lots of interruptions from hatches and masts, but cut little pieces to fit.
A full plank would be 16 feet to 20 feet long, 2" to 2 1/2" for you. A rule of thumb is that the ends fall in a regular staggered pattern, and the pattern repeats itself every “X” number of planks, “X” also being the number of frames the plank spans. In other words, if your plank is 16 feet ( or 2") long over frames spaced every 4 feet ( 1/2"), thats four frames. So the pattern repeats every four planks.
It’ll make more sense to you once you get going.
I hope that helps.
Bill
Hello!
I have only planked one ship model so far, but I was very pleased and pleasantly surprised with my results. It was a two-layer planking. First layer was done with linden/basswood with strips that I have cut myself using a small, soviet made circular saw. The chunk of wood that I have cut the strips from was laying in my workshop for about ten years, and I have got it from a toy factory, so I guess it was already seasoned when I have got it. To do the first layer of planking I had to wet the strips and bend them over a candle. That worked great. To glue them down to the bulkheads I have used a combination of white glue for most of the surface and CA instead of nails, at the critical points. As it turns out, those glues are very compatible and the combination worked very well for me. The first layer of planking was then puttied and sanded to ensure smooth and symmetrical surface. After everything dried really well I have done the second layer with veneer strips, the kit (Artist in the Latrine!) said the material for that was “Manzonia” which I guess means birch tree or something similar. Those strips were cut to exact shapes the planks would have. That means as the hull curves toward the bow and toward the stern, the planks get narrower, but newer less than half of their maximum width. This means notching the planks accordingly. The veneer was also glued with a combination of white glue and CA. The places where the dowels would be were marked with a ball point pen. The edges ot he planks were left natural colour.
I hope it helps, have a nice day
Paweł
Thanks Bill,great info that I did not know.Looking forward to planking my first ship!
Thanks Pawel, great advice on planking, I have an Endeavor that I will use it on but it’s down the road.I have three ships that I have vowed to finish first because they have been laying around too long.
I would not use contact cement for two reasons.
One, the solvents might react with the plastic–and not necessarily in an immediate or obvious way.
Two, contact cement is utterly unforgiving and very, very, permanent.
Now, I’m weird (you can ask anyone [:)]).
If I absolutely had to have a plastic deck (to align a multi-part hull or the like), I’d trace the kit deck onto some sheet styrene of a suitable thickness. I’d transfer all the openings over to that sheet as well. I’d dry-fit the planks as much as possible, and then lay them in a thin film of epoxy, and get them into their places.
Which sounds like a lot of work, but, adding planks to the kit deck is going change the reveal at hatch combings and the like, so, rather than fiddle with those bits, I’d just add them in wood.
But, my preference would be to start with a very thin bit bit of plywood as a base. If appropriate to the ship and the scale of the model, I set up beams to put dcamber in the plywood. Then, use the kit deck to sort out openings (while also refering to source material–if available). Planking can then be laid is regular white or carpenter’s glue, with all the forgiveness that allows. Hatches and the like also can be done up in wood, too.
But, I’m weird.
To be clear, are we talking about deck only, here, or do you mean planking the hull too?
He’s looking to modify a plastic ship kit, so I’d assume it’s the deck.
MicroMark also sells wood planking and “pre-planked” decking in 3 sizes I believe, including the 1/8" GM mentioned. I purchased their planks and did my own, but the preformed ones look quite nice as well. They use black glue between the boards which help them to stand out.
https://www.micromark.com/Ship-Decking?quantity=2&screwsizeinch=21
Bob
No,Just the deck,sorry, I should have been more specific.Any idea where to get these very thin deck boards? I assume the only thing you can get is ship hull planking used only for second covering of the hull.
Thats perfect,its just what I was looking for! Have you ever "blackened"the edges befor yo put them down?
For really thin wood, check out wood supply places for “veneer trim.” This is usually under 1/64" (around 0.3mm)
Now, 1/64" is 1.5" at 1/96 scale.
Which is where the pre-made sheets can get you into trouble. I want to remember the thinnest you can get, is 3/32" (2.38mm), which is 9" thick at 1/96. Which is going to be near as thick as the deck combings.
I have seen blackened deck plack edges work down to about 1/72 scale, but that was only just (and clearly a better than master modeler). I won’t bother if the scale is smaller than 1:48/1:50. Using black glue is really for moderate scales, like 1/32–although I have seen it used successfully at 1/48.
My 2¢; spend it as you will.
Individual strips come in 1/16". Which is 6" in 1/8" = 1’-0" scale.
On a warship like Constitution or victory, the deck planks are 3" thick.
Capn his model is the Revell Galleon, which has a pretty complicated little deck. I suggest just adding planks will be fine.
There’s a whole other job, to follow your advice, cutting a new deck, setting it lower by the thickness of the wood, and enforcing some camber with beams. I’ll put that up in a separate thread.
Hi ;
You have gotten very good replies here . My two cents ? I use Mahogany and or Oak . It is cut from the same wood as my friend’s Guitars and other Instruments . He takes the scrap and makes planking material for me . He , so far has never gotten it thicker than .020 .
He will run it through the planer when he’s shutting down for the day and call me to come and get it ! I get it home and cut it into planks 1/8 , 1/4 and 1/16 wide . Whatever length the pieces are . I then put them under a wooden plank of the 4"x 6" variety and 6’long and let them dry completely before use .
I use Carpenters glue on wood frames and C.A. On wood on plastic . I don’t do the latter till the planks are sealed and stained . C.A. will NOT let stain adhere . So you stain first !
My first stain is a wash of 50% x 50% Black India ink ! This locks in the grain the eye sees .
Wow ,never thought of India ink! Looks like I got my work cut out for me! As soon as I get done with this Soleil Royal I’m going to start on the Spanish Galleon.I will post a play by play on the deck boards.Thanks to all for the great response! While I have the opportunity I would like to personally thank G Morrison for sending me the parts to my Victory that were damaged in a flood.I had tried for months to get through to Heller with no response. So thanks again!
I have planked a plastic ship’s hull since the manufacturer (Heller) included no planking detail to go with the wood grain, which was heavily molded. In short, the kit hull looked like it had been simply carved out of a giant tree with no planks.
Anyway, like my namesake says, basswood works best for me, but I took a lazyman’s approach by simply matching the width of individual planks on other 1/144 scale ships. Since I also build plank-on-bulkhead kits, shaping individual planks is not a problem. I then sanded down the hull wood grain and used Gorilla Glue to affix the planks. I really enjoyed this minor project!
Bill
I love you like a father, well maybe a great-grandfather, Tanks.
But, I don’t think oak is a good choice. It’s brittle, it is hard to saw, and the grain varies a lot.
Since as I say I have a little table saw, I can try all kinds of stuff. Besides basswood, maple, holly and cherry are good. Pine is not good, and birch is too hard.
Bill
+1 on that. I avoid oak for those reasons, too. The grain is just too big for scale…
