This is a design of my own I entered in the Sci-Fi Ground Assault GB. Basically entry level to design AND scratchbuilding… Opinions welcome…
Some work in progress…
Basic ejection seat
I dont think I deserve that honor… [:I]
Well, if you want to get anywhere, you need a LOT of reference material. I also draw a LOT of PICS to visualise what I’m doing… Planning is important before doing anything. I usually take 2 months of R&D before I start building. In that time I plan, play, draw and think . I also test my materials, paints and everything. After that I’ve usually got a good idea what I’m doing…
love your artwork… awesome…
looks like the model will be just as inspiring, can’t wait to see how you’ll do the engines…
if I may ask what material(s) were used to make the gattling gun (small aluminum tubes?) , I need more of these (have been using 1/35 Vulcan parts)
Thank you for all the compliments. [:I]
You are correct in guessing aluminum tubes…
I use a dremel to turn neat styrene discs, drill the holes, slightly too small,
and shove the tubes into the holes.
I posted an earlier scale of 1:20, my mistake… [D)]
To allow a pilot to actually get inside the craft it is scale 1:24.
To answer the rivet question, I have a rivet tool (Basically a serrated pizza cutter). Doesn’t work too well on curvy surfaces though… For that I just use a scribing tool with a blunt point.
The engines - I have stolen and hacked apart all kinds of old electronics, printers,
a broken radio, yada yada to get some parts, tubes etc. Then some styrene to get the shape and a bit of kit-bashing (Looking forward to that… [^])
