I’ve been planning this for some time and started on her the end of January. Launch Table is complete, and the Tail Unit is ready for the thousands of rivets.
I plan on building the Atomic City Mercury Capsule to sit on top dressed as Gus Grissom’s Liberety Bell 7.
What a long dragged out process. I’m half complete with the rivets. I started applying the rivets on 6/18/18. So far over 2,500 have been applied. Guess I need to order more rivets……….
Are you dreaming about rivets yet? How many bits have you used up with the drilling? Do you fingers have any skin left on them? [8-)]
Seriously, this is showing both great dedication AND modeling skills. I am staying tuned into this build till completion. If the upper stages equal this part of the build, we are in for a treat!..
You would think. The Mercury Redstone was designed between 1950 and 1952 by Chrysler and was a direct descendant of the German V-2 Rocket which was also riveted together.
The entire rocket is not riveted. Only the Tail Section, and Instrument Section are riveted. A portion of the Propellant Section is, but most of it is welded.
