What colors do you recommend me using to airbrush onto my scenic grass. the setting is France August 1944 in an open meadow.
Thanks
Thanks
Probably medium to dark green and maybe a mixture of each.
Richard
John
What time of year are you setting it in?
I would start out with a dark to medium green and then dry brush lighter colors of green up through browns and yellows per the season that your setting is in.
This way you can get the color of the grass to reflect the proper shading from ground to tips of the blades.
Hope this helps
Cheers
Thom
