Such a great tutorial! Thank you for posting this, and thank you for making available your finished models. They are great for studying. [:D]
GAF - you are welcome [:D]!
In this post I will recreate the forward part of the wing root fairing. Basically, it is a variable radius fillet. It starts just at the wing leading edge and transforms smoothly into the cone of the rear wing fairing:
I extruded subsequent mesh segments of this fillet from the edge of the rear part of the wing fairing (from the point where I left it in the previous post). After each of these extrusions I decreased slightly the size of the last segment before extruding another one, obtaining in this way the variable-radius fillet:
Initially these new segments are disconnected from the fuselage mesh, although I fit them to both: the fuselage and the wing surface.
In fact the first two of these newly extruded fairing segments technologically belong to the rear part of the fairing. Thus I had to fit their surface to the three straight longerons that are there in the real airplane (I described details of this issue in the previous post):
The panel that connects the rear and forward parts of the fairing had a straight upper edge. Of course, I recreated it in the mesh (you can see it in figure above).
In the next step I merged these next three segments of the fairing with the fuselage:
Note that I added another section (edgeloop) in the middle segment of the fairing (as in figure above) — just to fit it better to the wing surface. I did not want to extend it across whole fuselage, thus I terminated it in a triangle at the upper edge of this fairing. Surprisingly, such a triangle does not disturb the resulting smooth, concave surface.
In figure above you can also see the auxiliary reference longerons, which helped me to ensure that this surface forms a straight line along their edges.
To merge the most forward part of this fairing with the rest of this mesh, I had to add more edges to the fuselage:
Each of these lengthwise fuselage edges “touches” the end vertex of corresponding fillet section. Once I placed them in this way, I removed the original fuselage faces and replaced them with the new ones. The right edge in each of these faces belong to the fairing:
When I did it, I used an auxiliary plane to evaluate the resulting cross-sections of this fairing along the fuselage centerline. It seems that the presence of the adjacent fuselage faces in the control mesh deformed the circular sections of the fairing around wing leading edge. I decided to fix this minor deformation by sliding the last edge of this fairing outside:
Finishing the wing fairing, I finished the main part of the fuselage:
In this source *.blend file you can evaluate yourself the model presented in the picture above.
In the next post I will form the bottom part of the fuselage (i.e. the part below the wing). I decided to build it as a separate object.
For this week I prepared the bottom of the SBD fuselage:
The designers extended the SBD Dauntless fuselage below the wing, creating there a kind of the bomb bay. However, it was too shallow to house even a 500lb bomb (see figure “a” below). (The ceiling of this bay was formed by the skin of the center wing). There was a single mounting point inside, and the bombs were always partially hidden in the fuselage. When the airplane was not carrying any payload, the bomb bay was closed by covers (see figure “b” below). They were bolted to the flanges punched in the fuselage skin along edges of this opening:
I suppose that in the future I will have to make some close shots of this area, thus I decided to recreate this detail “in the mesh”. This decision means that I cannot use the Boolean modifier to recreate this opening. In the effect, it will require much more work than similar details (like the landing gear bays) which I made in the wings. I will start working on the bottom fuselage in this post, and will finish it in the next one.
In one of the previous posts I created a reference shape that fits the contours of this bottom fuselage in the side and bottom views. Now I have turned its layer on, to see this reference object again (in figure “a” below it is in red):
I decided to create this part as a separate object — as it was in the real SBD. To begin, I copied the bottom part of the firewall into a new edge, and extruded it, forming in this way the first segment of the bottom fuselage (figure “b” above). Preparing for “cutting out” the bomb bay opening, I placed two sharp (Crease = 1) lengthwise edges in this mesh. They run along the opening borders (figure “c” above). To preserve the smooth circular cross-section of this body, these sharp edges are accompanied by adjacent, coplanar faces. (This is the same solution that I used for the rear gun bay opening in another post). These sharp edges will allow me to remove the faces from inside of this opening without altering the outer part of the resulting surface.
After extrusion of these initial two segments I extruded four more, up to the flap hinge:
I consequently marked as sharp the edges that follow the opening borders (as in figure “b” above).
When it was done, I created the bomb bay opening by removing its inner faces. I also removed most of the faces from the rear segment, because I have to modify the mesh in this area (as in figure “a” below):
In the view from bottom the rear edge of this opening had a circular contour. To recreate this effect I placed a quarter of 16-gon there (the symmetric side of this object on the picture is mirrored). Note the additional vertex at the external end of this “arc” — it helps to obtain a regular arc on the resulting curve. Then I projected (manually) the all six vertices of this polygon onto the reference body (see figure “b” above). Note also that the radius of this arc is a little bit bigger than in the bottom view on the reference drawing. After studying some photos I decided that it was slightly larger than on the reference drawing.
In the next step I extruded the inner segments of this edgeloop into a new surface strip:
Immediately after this extrusion I “flattened” this edge (by scaling it along the Y direction to 0), then adjusted its vertices on the XZ plane, fitting them to the reference contour. I also extruded forward the last vertex of this edgeloop, forming in this way the last straight segment of this opening border.
Finally I created new faces, filling the gap between these new edges and the remaining mesh:
When the central opening was formed, I extruded the tip of this body (the part below the flap — as in figure below):
I will have to separate this tip later, because it was attached to the flap. To ensure that this separation will not deform the resulting meshes, I marked the future split edge as sharp (Crease = 1). Then I adjusted shape of this tip to its contours on the side and bottom views. Finally I created the rounded tip, by rotating its last “bulkhead” edge around Z axis. (Frankly speaking, I can see no special reason for the existence of such a tip. I can only guess that, beside the aesthetic reasons, its presence allowed to preserve a little more height in the rear area of the bomb bay space.
I created the circular cut-outs for the wheel bays as in the wing — using the same auxiliary objects and additional Boolean modifiers (as in figure “a” below):
Strangely enough, for this object the Boolean modifier works “in reverse”, and I obtained the proper effect using the “Union” (!) instead of the “Difference” mode. Once I did it, I adjusted the shape of the wheel bay flanges, fitting them to the bottom fuselage (as in figure “b” above).
In figure below you can see the final object I created in this section:
In the next post I will continue my work on this assembly. I will recreate the covers for this opening, as well as their mounting flanges.
Sometimes the relatively simple shapes may require some substantial amount of work. In my previous post I created the basic shape of the bottom fuselage. It occurred quite complicated, because I decided to recreate the opening of the bomb bay “in the mesh”, instead of using the Boolean modifier. In this post I will complete the remaining details, enlisted in the illustration below:
I started by forming the bottom part of the fairing along the wing leading edge. It is not as difficult as the upper fairing. To show you the basic idea I just added a new edge loop near the firewall, then I moved down the corner vertex downward. As you can see below, the resulting surface starts to wrap around the wing:
Then I added another edge loop, adjusted locations of some vertices, and extruded fragment of this mesh in the spanwise direction:
As you can see in the figure above (left) I hid the upper edge of this fairing below the lower edge of the upper fuselage panel. (You can see these overlapping panels on the close-up photos of the real aircraft).
When I finished the wing root fairing, I recreated the bottom covers. I started each cover by copying the border edges from the adjacent meshes (as in picture “a”, below):
Then I adjusted these edges, matching the number of corresponding vertices. Once they were ready, I connected them with the strip of new faces as in figure “b”, above).
However, this cover was not completely flat! To fit it to the side view contour (and the reference shape) I inserted a new edgeloop in the middle of this mesh. Then I adjusted its height, fitting it to the contour of the fuselage:
These removable covers were bolted to the flanges that extrude from the bomb bay edges. To obtain a better fit, these mounting flanges were stamped by the sheet metal thickness (as in figure “a”, below):
How do I form such a “depressed” flange? I started by extruding its borders (see figure “b”, above). Then I connected these faces into a single strip (as in figure “a”, below). Finally I extruded these faces (not edges!) along their individual normals (I shifted the extruded faces using the Shrink/Fatten command) as in figure “b” below:
Finally I marked the outer edge in the control mesh as partially sharp (as in figure “c”, above) to improve the profile of this flange.
Figure “a” below shows the layout of the newly created cover panels. After all these modifications it is good idea to match this result against the available photos. As it often happens, I discovered that I should do it more often: there were some errors in this initial arrangement:
Well, in fact I had to rebuild anew the side doors and the rear cover (repeating all the tasks depicted earlier in this post). You can see the final result in figure “b” above.
Note that I slightly reduced the width (i.e. radius) of the rear cover. I decided that I was wrong estimating its size in my previous post. This time my reference drawing was right:
Figure above shows the completed bottom part of the fuselage (I hid the removable covers). As you can see, there still are many small details that I have to recreate during the detailing stage.
The issue that I had with the bottom covers shows that I should do such a verification from time to time! In the next post I will “step back” a little and match the overall shape of this model against the photos. I will do it using a new method.
Once again, beautiful work and attention to detail. While you cannot touch these models, I have seen some incredible artworks produced with virtual aircraft, so there is that.
I do wonder about using photos for reference, and how you know this image is from the SBD version you are attempting to model?
Gary
Gary, thank you! I will do my best ![]()
Some months ago I analyzed the differences between Dauntless versions. (You can find description of the identified differences in the previous page of this thread, in my posts from 11th ad 18th July 2015). One of the conclusions was that behind the firewall the geometry of this airplane remains constant from the first to the last version. The differences were in minor details: additional cutouts behind the gunner cockpit for the doubled ammunition feeder in the SBD-3, the reflector sight in the SBD-5 instead of the old-fashioned telescope. Thus I can use use every Dauntless photo.
P.S. As you have already noticed, I recently found the Britmodeller forum. Despite that I already have run this project for six months, I decided to start publishing the archival post there, because I think that it is another opportunity for interesting discussion. Initially I am going to publish these archival posts on that forum twice a week, so within a few months they will become up to date with this thread. Then I will continue tehse threads in parallel.
During the previous weeks I formed two main elements of my model: the wing and the main part of fuselage. As you saw, I could not resist myself for adding some details to the wing (like the ribs and spars of the flaps).
Now I think that this is a proper time to stop modeling for a moment and compare the shape of the newly modeled parts to the real airplane. If I find and fix an error in the fuselage shape now, it will save me from much more troubles in the future! If I find an error in the wing shape – well, I will have more work, because I already fit it with some details which will also require reworking… You will see.
The idea of using photos as a precise references emerged from the job that I did two years ago. One of my colleagues asked me if I can recreate the precise shape of the stencils painted on an airplane. He wanted to determine details of the numbers painted on the P-40s stationed in 1941 around Oahu. He sent me the photo. I started by fitting the 3D model to this historical picture, finding by trial-and-error the location and focus of the camera (as in figure below):
Then I made the model surface completely transparent. I placed the opaque drawing (texture) of the large white tactical numbers on its fuselage, and the black, smaller, radio call numbers on the fin. I rendered the result over the underlying photo, finding all the differences. Then I adjusted the drawing and made another check. After several approximations I recreated precisely shapes and sizes of these “decals”.
The key point in this process was to recreate the location and focus of the camera that was used to make the particular photo. Now I realized that it is possible to use the photos in the same way as precise references for my model. All I needed was a high-resolution picture.
I decided to begin with one of the archival photos of the SBD-5 from VMSB 231, made in spring 1944 (the original photo below is 2127px wide):
To find the camera projection that fits the model into airplane contours on the photo, you have to coordinate the location of the camera and its direction (I used for this purpose an auxiliary “Target” object). Yet another parameter to be adjusted is the camera lens length:
The whole process is an iteration: I started from a rough first approximation (as in figure above). Then I enhanced it, gradually determining the ultimate camera and target location, as well as the focal length.
In this process I based mostly on the elements which dimensions were determined by the “hard” evidence. It pays off that I placed most of the the fuselage mesh edges along the original bulkheads and longerons. (I will also benefit from this during further stages of my work). I was quite sure of the bulkhead stations because they were set according the original diagram. Thus I started by fitting to the photo the fuselage between the firewall (station 0) and the last bulkhead (station 271). Then I tried to find the proper camera focus that fits the middle bulkheads to the rivet seams and panel lines which are visible on the photo:
I was also able to fit to this photo the root rib of the outer wing panels. However, I could not match the position of the wing tip! When I fit this tip to the photo, the fuselage deflection was wrong. Otherwise, as you can see (in the figure above) the wing tip of the model was a few inches below the tip on the photo. I started to wonder why I have such a problem…
Figure below shows the best projection I was able to find. The fuselage bulkheads fit well the seam lines from the photo. It seems that the bottom contour of the tail was somewhat lower than in my model:
The only weak point is the different elevation of the wing tip. I cannot say that it had a greater dihedral, because it was dimensioned on the original general arrangement diagram (7⁰ 30’ along the upper wing contour, in the front view).
Finally I came to conclusion that what I can see on this photo is the elastic deformation (bending) of the loaded wing! This aircraft here is depicted in the flight, right? This means that these wings are carrying the load of about 4 tons of its weight. Their structure was stiff, but not absolutely rigid: every beam deforms (more or less) under the load. The airplane wings are not the exception: while flying in an airliner (like Boeing or Airbus) you can observe how their wing tips bend in the air. Of course, the relatively short, wide wings of the SBD Dauntless were much more resistant to such deformations. Nevertheless I think that we can trace the slight bending of this wing leading edge on the other shots of this airplane. For example, the white sun reflection on the photo in figure below allows me to reveal this dynamic deformation:
We can see here the bending of the outer wing panel. However, there was another deformation: in its joint with the center wing. The root rib under loads slightly rotates around the wing chord, which elevates the wing tip even further (in figure “b”, above). I suppose that the center wing was much stiffer (it had thicker airfoil and shorter span than the outer panels).
Using a side photo of a flying airplane, always try to estimate the elastic deformation of its wing, especially the wing tips! Usually such a deformation makes these photos less usable as the precise reference for a 3D model.
Frankly speaking, this conclusion was a little surprise. I have not noticed such a deformation before — maybe because I was mainly focused on the WW II fighters? Fighter wings are the stiffest ones…
In the airplane standing on the ground the wing deformation is minimal, thus such a picture suits better the reference purposes. Ultimately I decided to use some of the photos published by the Pacific Aviation Museum on flickr.com. Figure below shows the result (I had to flip this photo from left to right because I modeled the left wing):
As you can see, the wing perfectly fits its contour in this photo. I have found that the left aileron airplane was rotated upward by about 4⁰. I can see some differences in the hinge location of the upper wing flap (on the photo it seems to be placed at somewhat different angle, and shifted to the rear). The contour of the aileron bay also seems to be a little bit lower. On the fuselage you can see that the bottom contour of the tail is placed lower than in my model — confirming the observation form the previous photo.
When you find deviations as these that I have found in the aileron and flap hinges, it is always a good idea to check them on another photo. Thus I fitted my model into a different picture from the same PAM photo stream on flickr:
In this case I opened the wing flaps, because their straight contours helped me in precise positioning of my camera. It was possible to fit the bottom flaps to this photo (I just discovered that in this photo their deflection angle is 40⁰, while according to the specs it should be 42⁰). I was able to verify locations of their ribs and spars. (It occurs that these ribs, set according the stations diagram, are in the proper places). However, the upper flap did not fit properly into its contour in the photo. It was only possible when I shifted its hinge to the rear, placing it as in figure above. In this way I confirmed that these wing elements require corrections.
After these initial findings I decided to verify both: the wing and the fuselage, to fix all the differences I would find. Of course, it required more photos. Matching the model projection to a single picture takes me several hours of work (usually — one evening). I assigned to each of these pictures a separate camera (as well as the camera target object). Their names are three-letter shortcuts of the source photo followed by the ordinal number: thus PAM-1 means “Pacific Aviation Museum – 1.jpg”, UND-1 is “Unidentified – 1.jpg” and so on. I think that these reference pictures will be also useful in the future stages of this work. Switching between these cameras requires several steps: you have to type the path to the corresponding photo, as well as to alter the scene renderer aspect ratio. To facilitate this operation I created a dedicated add-on, which allows me to switch between these pictures with one click:
The ability to immediately switch between various reference photos definitely makes the difference! It encourages to study the same fragment from all possible sides.
The photos can be extremely useful reference, but they do not replace the traditional scale plans. First you have to create a 3D model that is close enough to the real shape, using the plans. Then you can project such a model onto a high-resolution picture for the further improvements.
In this source *.blend file you can evaluate yourself the model matched to the first picture from the Pacific Aviation Museum.
In the next two posts I will write about the results of this verification. In the first one I will describe the errors that I found in the shape of my fuselage. In the second post I will describe the differences that I found in the wing. Sometimes fixing these minor errors require several hours of work… But this is why we are the modelers (“a slightly different human being”
Currently I am using the method discussed in previous post to verify teh geometry of my model. It is a good idea to do it when there are no additional details. All the differences that I will find now will save me a lot of troubles in the future. For example — what if I would find that the base of the cockpit canopy in my model should be somewhat wider, when this canopy was ready? I would have to fix both shapes: the canopy and the fuselage. And what if I would already recreate the inner fuselage structure — the longerons and bulkheads — before such a finding? I would also have to fix them all. This is a general rule: the later modifications require much more work than the earlier ones! Thus I have to check everything when the model is relatively simple. You can compare the differences I will find in this post with the plans I published earlier in this thread: they contain various minor errors! Just as every drawing.
Last week (see my post from 2015-12-06) I discovered that the bottom contour of the tail was somewhat lower than in my model:
The main problem with mapping the tail shape was that its bottom part behind the wing was wide and completely flat. On every photo that I have the airplane is more or less deflected toward the camera, so the precise bottom contour of the SBD tail in the side view is an average of multiple estimations. That’s why it can be wrong on my scale plans! I also found a minor difference in the forward part of the fuselage below the wing. However, its forward part on the photo above is obscured by the truck. Nevertheless, I guess that the forward part of this cover it had a straight side contour, located minimally below than this contour in my model. To check this I mapped another photo of the firewall:
This photo confirms my observations from the side view picture. Although the bottom of the fuselage here is lacking the bottom covers, the corner of their mounting flange “touches” the bottom contour of my model. It means that the real contour was somewhat lower, more or less along the yellow line that I sketched on this picture. However, you can see here another difference: the upper part of the firewall is little wider than the elliptic contour that I assumed (It seems that the shape of the firewall was not an ellipse, as I assumed in one of the previous posts).
To make sure that this is not a mistake in the matching the model and the photo (or the effect of a barrel distortion), I also used another picture, from other restoration:
The photo above confirms that the fuselage was little bit wider at the cockpit edges than it is in my model. The trace of the bolt seams on the wing reveals another difference: the wing root fairing was also wider (at least its forward part).
To make sure that this difference is true, I have to find it on every photo that I map onto my model. Thus I mapped two other photos. They come from Pacific Air Museum. I can use them to verify the width of the mid-fuselage and the span of the rear part of the wing root fairing:
The good news is that the maximum width of my fuselage perfectly matches the photo (a good luck!). I found that the width difference at the cockpit edges found at the firewall is (approximately) constant along the whole length of the cockpit (figure “b”, above). It disappears behind the cockpit (i.e. in the front of station 140). The wing root fairing was somewhat wider at the trailing edge (figure “a”, above).
As usual, I used another photo to confirm these findings:
Because this photo depicts the whole fuselage, I had to check these details using higher zoom factors. This photo confirmed what I have found in the previous one. In addition, it seems that the width of the fuselage in my model matches the real contour of the tail up to station 271.
Once I confirmed all these differences, I had to fix my model.
The wider wing root fairing behind the trailing edge can create impression of lower tail contour on the photos taken from the side (in the first photo in this post). This is because none of these photos is an ideal side view shot. In each of them the camera was located above or below the fuselage centerline. That’s why I decided to begin by fixing these differences in the fuselage width:
Once they were corrected, I could fit the side contour, matching it to the horizontal photo of the tail:
As you can see in this picture, I also minimally modified the upper contour of the fuselage. (Because the upper arc of its cross sections was looking like a part of a flat ellipse, while it should be a regular arc).
Figure below shows the ultimate differences between the reference drawings I created several month ago and the contour obtaining from matching the 3D model to the photo:
As you can see, nobody is perfect, so I also did some mistakes. However, I was aware that the bottom contour of the fuselage was a guess: I did not have any photo where it was directly visible. All the pictures were taken from below or above, leaving some space for various assumptions (which often results in some errors).
Finally I fit the covers on the bottom fuselage (below the wing) to their contours in the photo:
I moved slightly downward the forward part of these covers. As you can see in figure “a”, above it was a relatively small difference. Initially I assumed that the cross sections of this bottom fuselage were elliptic arcs. However, in such a case, for the given width and height (from the side and bottom views), the edges of the wheel bays would appear a little bit lower than those visible in the photos. Thus I think that the contour of the middle cover in the front view had a slightly different shape (as depicted in figure “b”, above).
In this source *.blend file you can evaluate yourself the model from this post.
While matching the model to the photo (PAM-3) taken from left side, I noticed slight differences in the wing rib shape: it seems to be a little bit thicker than on the picture. I will analyze this and other differences of the wing in the next post.
In this post I will continue verification of my model by matching it against the photos. This time I will check the wing geometry.
In the first photo from the Pacific Aviation Museum (in my model it is marked as PAM-1) I identified several differences:
First I noticed that the hinge of the upper flap in my model is in the wrong location (I had to shift it forward by 0.7 inch). The upper edge of the aileron bay had slightly different shape on this photo. In this picture the tip of the aileron (the point lying on the wing tip outer edge) is located in the front of the corresponding point in my model. (The difference is less than 1 inch). Surprisingly, the inner (root) rib of the aileron seems to be a little bit higher in my model than on the photo. I can see also similar difference in the root rib of the outer wing panel. Location of the aileron bay upper edge on this photo can also be interpreted as located below the corresponding edge in my model. Does it mean that I made an error in forming this wing? The last visible difference are the outlets of the fixed slats. According the photo they were smaller and set at slightly different angle.
To check the differences in the wing thickness and the details around its trailing edge, I matched my model to another photo:
I opened the wing flaps to better match the projection of my model to this photo. I used the shorter edges of the flaps to precisely determine their deflection. The bottom flaps fits well into this photo (if you take into account that in the depicted airplane the outer flap is bent). To fit the upper flap I had to shift it by 0.8 inch, as shown in the previous photo (as in the first figure in this post). This confirms that there is a difference! What is interesting, the wing on this photo is also slightly thinner than in my model — which confirms that I made a mistake in recreating the shape of its ribs.
As I wrote, I was convinced that I properly recreated the airfoil shape. I used the original coordinates of the NACA-2415 (and NACA-2409) airfoils (as you can see in figure “a”, below)! Thus I used another, side photo (PAM-3) to check this finding:
The overall chord of the wing rib in figure above seems to be OK (luckily, on this photo you can see the fragment of the leading edge between the truck forks). The chord of its bottom flaps in my model also fits corresponding chord on the photo. However, the upper edge of the root rib in my model seems to be too high (by about 0.3 inch). I can see clearly that it occurs in the middle of the upper flange of this rib. On the scale plans this difference corresponds to just half of the contour line width! That’s why we have to use photos: the drawing conventions alone make the scale plans not as precise as we wish… The PAM-2 photo reveals that this difference (maybe somewhat smaller than at the root) extends over the whole wing span.
Well, so I had to fix it. While lowering the upper part of the center wing was relatively easy (figure “a”, below), I had also to modify all the adjacent objects — ribs, spars, and the fuselage
The more difficult was to make similar modification in the outer panels. The difference was smaller at the wing tip. To preserve the straight lines of the spanwise mesh edges I moved the whole selected area down by 0.3 inch, then compensated the difference at the wing tip by small rotation around the wing root chord. (I had to separately rotate each of these “longeron edges”). Of course, then I had to make a lot of minor compensations in the upper flap and the aileron contours.
However, I had to modify these trailing edge details anyway, following the other findings from the photos:
In this modification I had to revert the changes I made three months ago to the aileron bay edge (in my post from 2015-09-12 about details of the outer wing panel). It was the wrong location of the flap hinge, while the aileron bay edge should be in the place depicted on the reference drawings! In fact, drawing these scale plans I assumed that the hinge of the upper flap was directly above the hinge of the bottom flap. (You cannot see the difference on the most common, horizontal photos). Now I know that it is shifted away from the auxiliary rear spar by about 0.8 inch. After this modification I had to shorten the chord of the upper flap and rotate its ribs and spars, adjusting them to the altered directions of the flap skin. It required a few additional hours…
Once I finished with the trailing edge, fixing of the outlets of the fixed slats was easier. I just had to modify the shape of the “cutting tool” auxiliary object, used in their Boolean modifier:
Then I adjusted the slat internal surfaces, fitting their upper edges to these modified openings (as in figure “b”, above).
If I encountered such surprises on the upper wing surface, what do I find on the bottom of the wing? I started by examining the outer wing panel:
It was surprisingly difficult to find an appropriate projection for this wing — I badly missed the fuselage here! (It would allow me to better determine the proper direction of the camera). The barrel distortion of this photo could also have some influences on this matching. Fortunately, it seems that my model fits better this area of the real wing. The first difference I found was in the fixed slats: minor adjustment of their direction and sizes. I fixed them in the same way as their outlets on the wing upper surface (I will not bother you by describing the details). Another difference is more subtle: it seems that the real wing tip has slightly different shape than in my model!
Of course, I had to check it on another photo, taken from another direction:
This photo confirms my finding: it seems that I made another wrong assumption about the shape of the wing tip. (I assumed that the rear part was a single arc, while it is at least a smaller arc and an unidentified curve — maybe short piece of another arc of larger radius?). Of course I accordingly modified the wing tip (by adjusting location of a few of its vertices — in fact it was not as complicated as it sounds).
For the complete verification of the wing, I used the picture from the SBD manual. I checked the bottom surfaces of the center wing:
To speed up narration in this post, the picture above is showing the updated mesh. I just enlisted the modifications that I made. As you can see I had to adjust the outer edge of the wheel bay (because it was not a simple circle). There were some minor differences in the split lines of the bottom covers (I had to adjust the bottom fuselage! Again!). Ultimately, I discovered that I placed the fixed ribs above the flaps in wrong locations (I really do not know why I not followed the stations diagram— now I corrected this mistake).
This is the last post about this “great verification”. Now I am coming back to modeling. In next two posts I will recreate the empennage of this aircraft.
In this post I start to work on the tail assembly. The horizontal tailplane has similar structure to the wing — but it is simpler. Thus I started it in the same way as the wing, by forming its root airfoil:
In the most of the aircraft the tailplane has a symmetric airfoil. So it was in the Dauntless. I did not find its signature (family) in any of the reference materials, thus I carefully copied its contour from the photos (its rear part — the elevator — seems to have modified shape, anyway). It has incidence angle of 2⁰, so I rotated the rib object and used a Mirror modifier to generate its bottom part.
During this work I decided that I will use this rib as an auxiliary reference object for shaping the horizontal stabilizer. To precisely match the contour copied from the photos, I rotated part of this curve in the top view. Now it runs along the outer edge of the tailplane fairing:
However, because I am going to copy this rib into the initial edge of the horizontal stabilizer, I already prepared three vertices for the leading edge of the elevator (as in the figure above).
During this work I was struck by the idea that it is stupid thing to model the whole empennage, and then to verify it against the photos. The much better approach is first to “draw” in the 3D space their contours and match them to the photos, then to model their surfaces. In this way I can identify errors in my reference drawings before I start the modeling! The parts formed in this “verified” way and continuously matched to the references will have better quality!
Thus I interrupted forming the horizontal tailplane, and quickly shaped another auxiliary object — the contour of the rudder and fin:
What’s more, I decided to recreate in the model the basic reference “trapezes” of the fin and rudder. They are determined by the explicit dimensions in the general arrangement drawing, which I already used some months ago to draw the 2D reference drawings:
While in the model space the 1 unit corresponds to 1 inch, I did not need to multiply every dimension by the scale coefficient. It was a big surprise when the trapeze drawn according these re-applied dimensions occurred shifted left by 0.7”!:
I immediately did the same test for the horizontal tailplane. It also was shifted by 0.7”!:
Well, such a coincidence suggest that I made a kind of systematic error in calculating locations of the elevator and rudder axis for my scale plans. Most probably there was something in their extremely long position, measured from the wing leading edge (see the general arrangement diagram in the fourth figure from this post). For example, it could be a rounding error of the scale coefficient!
If I was wrong in this case, I could made other errors. I decided that it is proper time to re-use the original photos from the web page of Chino Planes of Fame Air Museum. Their resolution is only half of the resolution of the photos from Pacific Aviation Museum Pearl Harbor. However, they were made using a long-lens camera. (You can read that the standard length from the EXIF section of the Chino photos — it was 400 mm. The photos from Pacific Aviation Museum Pearl Harbor were made with the standard lens length: 36 mm).
Using this focus length, it is easier to fit the model and the photo:
As you can see, this is a flying airplane — and there is no visible dynamic deformation of the wingtip! This means that the whole “theory” about the wing deformation that I described in my post from 5th December was wrong! The wing is much stiffer than I thought. The deformation of the historical photo can have other reason. It could be significant barrel distortion of its lens, or the deformation of the negative. I do not know.
I verified contours of the horizontal tailplane by matching the model to another photo:
Note, that this is another photo that I used to draw my scale plans. However, this time I left it unaltered, to avoid eventual errors that I could made by setting it horizontally and scaling.
In general, the model fits this photo pretty well. However, there are small differences at tailplane and wing tips. I started to suspect that such a photo can still have a small barrel distortion.
Finally, I used the third Chino photo to further verify the side view:
The dimensioned contours of the empennage helped me to match better the other photos. For example, I slightly updated the projection parameters of the SBD-5 pictures from Pacific Aviation Museum Pearl Harbor:
The contours of the tail and fuselage fits the photo pretty well. There is just a visible difference in the wing tip spans — I think that this is the effect of the barrel distortion.
Well, I started to build the tailplane in this post, but this process ended in another verification. However, it spared me from similar check that I would have to perform on the finished empennage. Now I can quickly build this assembly — in the next post I will finish the horizontal tailplane.
I think your supposition about wing “deformation” in flight is correct, except it is not uniform throughout the flight. Wing “wobble” is present in most aircraft to a greater or lesser extent, so using an image of aircraft in flight by over-laying your model for wing positioning and dimensions is only approximate.
http://www.ondair.net/the-science-behind-why-airplane-wings-wobble-in-turbulence/
If you can get your tolerances down to only around 1/8 inch, then you’ve done extremely well.
Thanks for posting this great tutorial!
Gary
Thank you, Gary!
You are right - I think that the truth “lies in the middle”, as usual: sometimes there can be a small influence of the dynamic wing deformation (even more or less “wobbling”), in other cases the picture on a photo can be deformed because of different reasons…
After some verification of the reference contours that I described in the previous week, I am coming back to modeling of the horizontal tailplane.
In the previous post I created the reference airfoil of its root rib. Now I copied it into a new object, straighten along the fuselage centerline, and finally extruded spanwise:
I checked the resulting shape, ensuring that the thickness of the tip ribs matches their counterparts on the photos:
When this base shape was verified, I started to form the curved contour of the tip. Basically, it was an arc, thus I shaped it by extruding and rotating subsequent mesh segments:
Preparing the horizontal tailplane for such a mesh topology, I used the same number of rib vertices to form the leading and trailing edges of its root airfoil.
In the next step I created an additional gap in this mesh, at the point where it will be split between the stabilizer and the elevator (as in figure “a” below):
Such a gap deforms the original circular contour of the tip. To restore its shape, I had to move a little two nearest vertices on each side of the gap. Facilitating this task, I used an auxiliary circle as the reference shape.
To fill the empty space inside the tip, I extruded the internal edges of the last rib (as in figure “b”, above).
I slid the last vertex of the edge that runs along the elevator leading edge, forming in this way the angle visible on the reference drawings (as in figure “a”, below). In fact, its location was re-checked on the reference photos, thus it lies in a slightly different place than you can see on the underlying scale plans.
Of course, I also scaled the thickness of this newly formed “rib” (as in figure “b”, above), aligning it to the slope of the previous, trapezoidal segment of this tailplane.
In the next step I started to build different topologies in each part of this tip mesh. In the “stabilizer” part I joined the “tab” of the internal faces and the leading edge (as in figure “a”, below). In the “elevator” part, I removed the first and the last face of this tab, and shifted the vertices of the middle face, forming a thinner trapeze. Then I extruded the outer edge of this face several times, rotating them around the “corner” of the elevator leading edge. Note that each of these faces corresponds to a single mesh segment on the tip external contour:
I also joined the “gap” in the tip contour into a single, “sharp” (Crease = 1) edge. (In fact, I should create it as a single sharp edge in the beginning). Such an arrangement allows me to quickly create an array of new faces that closed the tip of the elevator (as in figure “b”, above). Note that I filled the gap in the “corner” using two quad faces.
To match the topology of the elevator tip, I had to add additional “rib” to the stabilizer mesh. I did it in three steps. First, I created edges that joined the corresponding vertices of the tip external contour and the internal faces (as in figure “a”, below). Then I split them by half (using the Subdivide command). Finally I used all these vertices to create new faces (as in figure “b”, below):
Note that I had to create a single triangular face near the leading edge (see figure “b”, above). Fortunately, the mesh curvature in this place is low enough that it does not disturb the resulting, smooth shape of the tip.
When the overall shape of the tailplane was ready, I split it into the stabilizer and elevator objects. I did it by copying the original object and then removing the “elevator” part of its mesh faces (figure “a”, below):
Similarly, I removed the “stabilizer” faces from the elevator object (see figure “b”, above). Ultimately I also simplified this mesh by removing one of its “longeron” edges. (It seems that the tip contour in the front view requires just a three-point curve).
The elevator of the SBD Dauntless had an oval leading edge (it was the aerodynamic compensation, an area shifted in the front of the hinge line). I started to form this element by inserting on the symmetry plane a circle (consisting 12 vertices):
Then I extruded it spanwise, adapting its radius to the local airfoil thickness (as in figure “a”, below):
In the next step I removed the rear faces from the leading edge cone, and joined it with the rest of the elevator mesh (see figure “b”, above).
The presence of a single middle edge in the elevator tip allowed me to remove similar edge from the stabilizer tip (as in figure “a”, below):
Of course, it would be even easier to not create this edge at all — but this is typical situation, when I modify the initial concept of the mesh topology during the progress of the work. Figure “b” (above) displays the resulting tailplane assembly.
In the next post I will describe my work on tailplane fairing.
In the previous post I formed horizontal tailplane of the SBD Dauntless. In this part I will describe how I created the fairing between this tailplane and the fuselage. It is an easier part than the wing root fairing, because it is smaller and most of its cross sections are not circular.
At the beginning I cut out from the stabilizer its middle segment, along the root rib:
Then I “draw” the outer contour of this fairing in the side view. I also checked it in the reference photo (as you can see in the figure above).
Then I projected this “sketched” outer contour onto the fuselage. I did it by extruding its polyline into a face strip that crosses fuselage surface (figure “a”, below), then finding the intersection edge of this mesh with the fuselage (figure “b”, below):
The intersection edge was calculated by one of my Blender add-ons (named Intersection — you can download it from here). In general, it would be easier to extrude this edge horizontally (because I sketched this contour in the side view). However, I was afraid that the add-on will lost the track of the upper rear part of this mesh (the part that crosses just the upper tip of the fuselage surface). That’s why I initially shifted this contour close to the fuselage, and extruded it in a more-or-less perpendicular direction to the fuselage surface.
All in all, after this operation I have the three edges, which is enough to create the first version of a smooth fairing:
Figure below shows the initial smooth, subdivided mesh based on these three edges:
It starts to resemble the original element. I created here the new row of faces, from the middle edge to the outer contour. Then, before creating this screenshot, I switched the display mode to the resulting subdivision surface.
To have better control over the shape of this fairing, I inserted two additional edge loops into this mesh
These additional vertices were extremely useful in shaping the bottom edge of this fairing, which had a semi-circular cross section:
In the most of the aircraft designs the fairing is just a piece of sheet metal bolted over the fuselage skin. In the SBD Dauntless it was an integral part of the fuselage skin (except the area around the stabilizer leading edge). Thus I had to extend the bottom part of this mesh, copying the fragment of the fuselage surface (as you can see in the figure above).
Figure below shows the finished fairing. As you can see, it smoothly fits the fuselage:
It was not necessary, but I also created the rear spar of this tailplane — just because I do not like to see a large empty space in a finished element (the fuselage is not finished, yet!).
In the next post I will create the fin and the rudder.
This week I have worked on the SBD vertical tailplane. I started by forming its root airfoil (see the figure below). I had no description nor a direct photo of the airfoil used here. However, the reference photos reveal that it could have similar shape to the airfoil of the horizontal tailplane. Thus I copied that curve into this mesh.
Note that I used here a thin strip of the faces instead of a single curve (which I used in the case of the horizontal tailplane or the wing). The reason is simple: on the single subdivision curve I cannot mark a “sharp corner” at a control point (original mesh vertex). On the face “strip” I can mark the corresponding edge as sharp (increasing its Crease coefficient to 1). I marked in this way the edge at the split between the rudder and fin. Simultaneously I can form such a face strip in the top view as easily as a single curve. (I just have to remember to select its vertices using the group select commands (Border-select or Circle-select), instead of the simple mouse click). Why didn’t I use this method in the previous cases? Well, good ideas require some time to emerge…
Once the root airfoil was ready, I extruded it into the basic trapeze:
Then I split this mesh into the rudder and fin (i.e. into separate objects, as in figure below):
Note that I added additional “rib” edges to the mesh of the fin. They will be useful in forming the forward fragment of this part.
Initially, I extruded the first approximation of the dorsal fin from the bottom edges of the lower ribs:
However, I decided that the resulting topology of this mesh differs too much from the original layout of the panel seams (and the original ribs and spars). To make a better approximation, I used the fin shaped in the previous step as the reference object (in the figure below it is in red):
I cut out the forward part of the original fin, forming in this mesh the first vertical edge. Then I extruded it into next segment:
The next segments were extruded in similar way:
In each new segment the vertical cross section is significantly smaller than in the previous one. I had to compensate it by cutting out its bottom fragment (using the Knife tool — as in figure above) and reducing the number of remaining faces.
Figure below shows the resulting dorsal fin:
The tip of this fin was formed in an unusual way — it was stamped in the cover of a fuselage hatch (as you can see on the photo). I will form this cover later.
Figure below shows the objects created in this posts:
You can examine them in this source *.blend file.
In the next post I will describe my work on the fairing of this fin (it seems quite simple, but occurred more difficult than I expected!).
In the SBD Dauntless the fillet along the fin and the fuselage was formed from the bent bottom edges of the fin panels. I am showing it in the figure below:
(To make some of these panel seams more visible on thee photos, I sketched along them thin lines). You can observe that each fin panel overlaps the next one, starting from the tip stamped as the part of one of the fuselage doors (see the second-last figure in the previous post). The outer contours of these panes are not perfectly aligned: you can see small overlaps on the photos (see the figure above). Surprisingly, such a detail makes the modeling more difficult. However, the most difficult part will be the seam between the fin and the horizontal tailplane fairings (as in the figure above). It runs along the fuselage longeron, across the fillet between the stabilizers and fuselage.
Well, I started this fillet by extruding some faces from the bottom edges of the fin mesh:
As you can see, I already recreated the sharp panel corners in these extruded faces. Then I lowered their outer edges and aligned them to their contours on the top view:
This is the first, rough approximation that fits these panels to the fuselage surface. In this process I discovered that I had to make some modifications to the upper part of the tailplane fairing. However, I was not entirely satisfied with the result: comparing to the photos, something was wrong at station 242 (see the figure above). The outer seam of the fin fillet should be a little bit wider here!
After some additional deliberations I decided that the fuselage under the fin was somewhat higher (by about 0.5”) than on my reference drawings, and the upper arc of these bulkheads had larger radius. Thus I had to modify this part of the fuselage:
I rotated a little this mesh fragment, then scaled up the upper part of each of its three bulkheads.
I had no photo of the SBD fuselage without the fin, taken from the side. In fact, the shape of this fragment on my scale plans is in 80% my assumption! Such small anomalies as this one helps me to discover the real shape of this airplane.
Basing on the corrected fuselage, I was able to fit better the outer edges of this fin to the fuselage and the tailplane fairing:
However, I was not satisfied with the forward part of the seam between these two fairings: despite all my efforts, it looked a little bit sharp!
Ultimately, I had to reshape a little bit the tailplane fairing and cut out the excess of its surface along this seam using a Boolean modifier:
This method produced results that resemble the smooth shape that I can see on the photos:
However, I do not like such a “Boolean – based” solution. It seems too complicated. In the next post I will try to eliminate such a “hard” seam between these two panels. I think that much better solution here will be a continuous, smooth surface. The seam can be recreated later, using textures.
Anyway, in this source *.blend file you can evaluate yourself the model from this post.
After the previous post I decided to simplify the empennage fairing. Originally I created it from two separate objects: the fin fairing and the tailplane fairing, split across their fillet. Now I decided to eliminate this troublesome seam by joining these two meshes into single object:
I will split it later, along the bottom rib of the fin (there was another panel seam in the real airplane). To simplify creation of the original overlapped panels, I simultaneously split the fin into the forward and the rear part, along one of the original seams.
As you can see in figure above, there are the same number of spanwise edges on both fairing meshes. It is a matter of sheer luck, but it makes the process of joining these two parts much easier.
First, I modified these edges, bringing them closer to each other. (I did it by sliding their vertices along perpendicular edges — as you can see in figure “a”, below):
Then I removed the unnecessary faces (as in figure “b”, above).
Finally I filled this gap with new faces, effectively merging these two meshes (figure “a”, below):
In the side view (as in figure “b”, above) you can see that the forward part of the fin extends a little the panel line visible on the reference drawing. It will be overlapped by the forward part, which will end precisely along the original seam. (Such an overlap is visible on the photos). Note also that the seam along the fuselage upper panel (marked on the drawing by the dotted line) is somewhat higher than on my scale plans. This is the effect of the modification that I made in the upper part of the fuselage (described in my previous post). My reference drawings are simply wrong about its location in the side view.
I think that the empennage fairing looks much better after this modification:
It fits well all the three elements it joins: the fuselage, the fin and the tailplane. The fillets looks smooth and natural. As you can see, I split the fin and the fairing along the bottom rib edge, as I planned. (There was original panel seam). I think that this new arrangement of the model objects will facilitate further detailing of this assembly (for example, now the forward fin panel overlaps the other elements, as in the real airplane).
The last element of this assembly is the fin tip: in the real airplane it was stamped in one of the fuselage inspection doors. I started to form this part by creating a plain, rectangular cover placed over the fuselage, and separating the corresponding fragment of the fin tip (figure “a”, below):
Then I joined these two object into a single mesh (figure “b”, above).
In the next step I adjusted corresponding edges of both elements, and removed the unnecessary faces (figure “a”, below):
Finally I filled this gap with new faces. Finally, after some rearrangements of the mesh topology, the resulting elements looks like in figure “b”, above).
Figure below shows the final object, fitted to the fin and the fuselage:
The last element that I need to finish in this empennage is the rudder leading edge. I created it in the same way as the leading edge of the elevator: from a single circle (see my post from January 9th). I extruded it into a cone (figure “a”, below), then removed the unnecessary faces and created new ones (figure “b”, below):
Figure below shows the completed empennage (note that I also created the fin spar):
The last missing element is the tail tip. It has a rather complex shape, so I started modeling this part by copying its outer edges from the fuselage, fairing, rudder and elevator. You can see them in the picture above. I do so when I have no clear idea how to start. In the next post I will describe what I did next.
The tip of the SBD tail was a light fairing, attached to the last bulkhead (at station 271 — see figure “b” below). That’s why you can see “NO PUSH” label on the photo in figure “a”. The tail wheel was attached to the bulkhead 271, which transferred the resulting loads forward, via the tail structure. The tail tip fairing was always free of any significant loads. However, the shape of this part is a combination of the empennage fairing and the last fuselage segment. What’s worse, there is a large opening at the bottom — for the eventual tail wheel deflection:
I had no initial idea about the mesh topology that I should use for such a part. Thus I started by copying all of its external edges from the adjacent objects (see figure “a” below):
Then I worked out an idea of its topology by sketching possible mesh edges on a scrap of paper. (I often do that before I start modeling a complex mesh). You can see the scan of my sketch of this tip in figure “b”, above. I “think by drawing”, so this method helps me to better realize the shape that I have to create. These working sketches object do not have to perfect. The more important thing is the order of the individual edges and vertices (identified by the numerical IDs).
When the mesh topology on the sketch looked simple enough, I started building this mesh by extruding the trailing edges of the elevator fairing (see figure “a” below):
Then I extruded the upper edge of the elevator fairing into another rectangular “patch” (see figure “b”, above). In the next step I extruded similar “patch” from the rudder contour (see figure “a”, below):
Finally I filled the gaps between these three mesh “patches” by creating two rows of new faces (as in figure “b”, above).
The resulting subdivision surface required some minor adjustments of the control mesh vertices. They formed the proper shape of the mesh behind the elevator trailing edge (figure “a”, below):
While sketching this tip, I decided that it will be better to close it with a separate object — the “closing strip”. Such a strip reproduces the original piece of the sheet metal that contained the frame of the running light. (I thought that the side-view contour of this tail tip might require different edge distribution than the mesh of its sides). At this moment I created the initial segment of the “closing strip”: the part around the running light frame. Then I used it as the reference object for shaping the mesh of the tip sides (see figure “b”, above)
I split the model surface into separate objects when I expect significant differences in their mesh topology. I “mask” outer edges of such objects by placing them along the original panel seams.
When the upper part of the tip was ready, I started forming its bottom part. As you can see in figure below, I did it in the same way as the upper fairing. First I extruded a part of the bulkhead contour (figure “a”), then I created new faces to incorporate this patch into the main mesh (figure “b”):
I extruded the side faces of this tip from the bulkhead edge (figure “a”, below), then filled the gap in the resulting mesh by creating a row of new faces (figure “b”, below):
(Note that I had to create more “bulkhead” edges in this mesh than I originally sketched (see the second figure in this post). Some of these edges came from the original vertices of the elevator edge, while the other were required by the shape of the bottom edge (around the tailwheel opening).
The ultimate number of edges in a mesh is often the sum of the vertices required to obtain appropriate shape on its opposite border edges.
Finally I extruded and merged the last part of this tip:
As you can see in figure “b” above, I added an additional, diagonal edge below the trailing edge. I did it to obtain a better shape of the elevator fairing
Figure below shows the smooth resulting shape:
I had no photo taken from the top or the bottom that would precisely reveal the vertical contours of this part. Thus I assumed that this tip is a smooth continuation of the tail cone (as I marked with the dashed line in Figure 38‑9). In the next post I will verify this assumption using available photos.
In the previous post I formed the shape of the SBD Dauntless tail tip. In this post I will finish its “closing strip” that contains the running light frame. I will also verify the overall shape of the tail tip using the available photos.
There is one thing I didn’t mention in the previous post, just to keep the narration focused on the pure modeling. Before the modeling I carefully studied the reference photos. In the result I found differences in the shape of the curved trailing edges of the fairing behind the elevator. On the photos you can see a straight fragment of this edge (figure “a”, below). Its presence means that the curve of the trailing edge was smaller, and the fuselage was somewhat thinner here. You can see the differences between the real shape and my reference drawing in figure “b”, below:
I did not notice these detail before. As you can see, I applied this modification when I started to model this part.
When the mesh of the tail tip was formed, I worked on the “closing” strip. I created a part of it as a separate object in my post from 2016-02-13. Now I extruded it along the side contour (see figure “a”, below), then extruded the side faces of this strip (figure “b”, below):
I rounded the sharp edges of this element with a fillet. It is dynamically generated by a multiple-segment Bevel modifier — you can see the result in figure “a”, below:
However, when I compared the bottom part of this tip to the photos, I saw that there are significant differences! Jut compare it in figure “a” and “b” above. The side edges of the tailwheel opening are less curved, and its rear edge is wider.
What is the reason of these differences? So far I tried to shape the bottom part of this tip as the smooth continuation of the previous tail segment (see figures “b” and “c”, below). It seems that I was wrong: these lines were broken at station 271, where the tip fairing was attached to the last bulkhead of the tail (see figure “a”, below):
To correct this shape, I first made the tailwheel opening wider by rotating the bottom part of the mesh:
Finally I adjusted the shape of the “closing” strip to this new opening (figure “b”, above). Now it resembles the original in the photo.
When I fixed the shape of this opening, I noticed another difference, this time in the shape of the tip cross-section. It is revealed by the vertical panel seam behind the tailplane:
This vertical seam seems to be flat, especially in the restored SBD from figure “b”, above. In my model this line is much more convex (figure “c”, above).
The primary reason of all these differences between my model and the real airplane is the lack of the reference: I have no photos of this fuselage tip taken from above. Thus I have to determine its shape on the plans by various indirect means — and assumptions. In such cases, when you shape it as a 3D model, you will often find errors in the reference drawing.
Well, to make this section more “rectangular”, I have to make the fuselage even thinner in this area:
Yet the photos reveal another small difference, this time between the two different restorations of the SBD Dauntless: compare the photos “a” and “b” in the second-last figure above. The aircraft from photo “a” has the edges of the tailwheel opening bent inside, while in the SBD from photo “b” the tip cross-section contour is straight to the end. Which one is true? At this moment I do not know! However, it will be better to modify the mesh of this tip in a way that makes such a rounding possible. (You can always straighten a curved surface. However, bending a flat mesh requires additional edges). That’s why I modified the mesh topology around this opening, adding another “longeron” edge (figure “a”, below):
Then I shifted two bottom edges a little (figure “b”, above), forming such a cross section as you can see in photo “a” (compare it with the shape in figure “c”, above).
Below you can see tip, finished for now:
I will recreate its internal reinforcements (bulkheads, stringers) later, during the detailing phase. At this moment I do not know whether I have to modify this part in the future. (It may happen when I find a better reference materials). Such a modification would require adjusting these internal structures, so it is better to postpone their creation as long as possible.
In the next post I will start to work on the engine cowling.
You’re pretty good at pushing verts, Witold! I’m envious. ![]()
