I recently obtained a Revell-Monogram Pro Modeler SB2C-4 Helldiver, kit number 85-5935, that is missing the instruction booklet. If someone has a copy that they are not using or will make copies of one and send to me, it would be appreciated. I will reimburse for copying and postage.
Heh … I got the exact same kit and “lost” mine too. Tme to do a little searching. If I find it, I’ll make copies and send them to you.
Both of you send me your emails in a PM and i’ll scan mine. I’ve got the instructions for every kits I’ve built since getting back into in aught 5
OK! Lets Interject a little humor with the problem, “Real Men Don’t Need Instructions!”
I have the instructions for the Pro-Modeller Kit. If Wing Nut can’t send them to you , let me know. The problem I have is that the port side of my aircraft did not get fully cast leaving a hole/gap in the side. I have been looking for a replacement, but so far no luck. When I wrote to Revell, they said they no longer have that mold. I was wondering if anyone has checked out the new Helldiver by Revell against the old Pro-Modeller kit and if there are many differences? If not, what is the part number so that I might request one from Revell?
The Revel-O-Gram mold went to Pro-Modeler then to Accurate Miniatures. I have the AM instructions but it should be the same all around. All scanned and ready to pg. Just haven’t heard from either fella yet.
I have found mine in the most obvious places.
PM sent to TEEKAY
Thanks for the offer. I have sent a PM to Black Sheep Two One Four and he will be sending me the instructions.
