RUSSIAN T-90 MBT 1:35
Nice work,can you tell me about the white wheels,I never seen that scheme before,and which kit is it.I have the Meng in my stash
Great looking tank Alexander. I’m not too familiar with the more modern Soviet armor so I’m interested in what the red dots on the interior hatches represent.
Very nice built and colors…as Mike said, what are those red dots in the hatch?
As rodas não são brancos, mas a luz cinza-pesquisa na net você vai achar que este esquema
Eu não falo para as marcas de fabricante - (é o kit com “turret cast”)
The mystery of the red dots is very simple! -it was just my idea.
The wheels are not white, but gray-light research on the net you will find that this scheme
I do not speak for manufacturer brands
Well thanks for the info,I know I can research the net,I was trying to have a conversation about your build.And I wasn’t asking you to advocate a brand,just wanted to know what kit it was,unless you scratch built the whole thing.
Oh, and I see that you “spoke for a manufacturer brand” in your post about your Trumpeter Maryland
Quando falei sobre a marca kit Maryland deve ser bebido
O kit é “russo T-90 MBT-CAST-TURRET” mercado único
-1300 Peças total na caixa: -986 vinil e plástico +313 peças PE
-Usado em construção: -1065 peças.
836 Plástico e vinil+ 229 PE = 1065
Well,thats a good rerason,sounds like the Meng,as i said nice work,I hope to start mine this year
Hi Alexander,
That is indeed a very powerfull T-90 build!
I especially like the capture of the “Shtora” advice and the way you have brought the front to live.
Bit curious though, the Zvezda offering was accused of sitting to high, the suspension parts just moved the body proximate 4" to high.
The MENG should not have that problem.
This is a cast turret and the only manufacturer I know would be Trumpeter and I am seeing the same issue.
Is this the Trumpeter?
Thank you for sharing!
Very Best Regards
Johan
Johan, it is possible there is a problem with the turret of which you speak, but I can not say anything about this matter.
We carry not sink these technical details.
It is my intention to build based on the kit and from time to time add something or change colors.
I have received harsh criticism for not doing everything politically correct, but it does not affect me, continual enjoying myself and spending time in my own way.
best regards to you
A.Alexandre
