Modelers, I’ve finally found the scheme I want to use for my MIG-15bis. The scheme calls out Humbrol 115 Russian Blue. However, I look this up to hopefully find an equivilent in another brand and it says this color is discontinued. Does anyone by chance know what other brand of blue could pass as this color?
And finally there’s this one: http://www.ipmsstockholm.org/colorcharts/stuff_eng_colorcharts_humbrol.htm
which leads us to believe there’s no current equivolent available. Your best bet might be to check your references to see which USSR color matches the one you’re looking for and then go with the mixing instructions mentioned in the second link. Good luck!
If you turn the Vallejo 972 into their model air colour, then it would correspond to number 008, which in turn can be considered the same as RLM 65. Then you have the choice of which paint manufacturer you prefer.
Bones, you could use Tamiya XF-23 for the underside blue. It’s a little lighter than Humbrol but this should be OK since paints darken considerably when over-coated for decaling.
