I have finally found a way to mix paint with a dremel.
Now I know that I am not the only one who’s thought of this but I have found a way it will work.
However you must do this with a dremel mini mite on low speed or a rotary tool with a compramel speed.
#1) Take a straight piece of 3" sprue(the plastic frame the part come on).
#2) Put heat to one end of the piece until it is soft.
#3)flaten out the soft plastic with a pair of pliers (or what ever is handy).
#4)Place the piece in the chuck of the tool.(you may have to adjust the collets or sand down the shaft on the piece).
#5) Last (and most important ) item.
place the mixing bit in to the paint jar or cup BEFORE you start the tool up.
If you don’t do this you will be a mess.
P.S.) one more thing.
Use the lowest speed possable on your rotary tool.
(the slower the better)
I hope this works out as well for you as it did for me.
Thanks and good luck.[;)][;)][;)]
