Force9
First off, thanks for the compliment and I am looking forward to your next post on your Connie build. As for highjacking…please feel free. Your insight and knowledge is always a welcome addition.
And thanks again John for the beautiful deck. I think it takes the model to a whole other level. (And no one I know that will ever see this first hand will be any the wiser about the butt pattern).
I got started on the spar deck by pulling parts and laying them out for fitting and replacing the belaying pins. I got to the ramp thingy (part 140) that goes up from the deck to the bow sprit, took one look, and thought “No effing way am I going to use this!” So I pulled out my Bluejacket plans and am going to do my best to follow their layout.[ I am soooo happy I invested in them]
In doing so, I had to overcome a few problems. The first being that as I went to set the bow sprit in for fitting, the part that it seats on popped out of place. Of course! The part being on the gun deck, and the spar deck now and forever in place, getting it put back in, entailed a copious amount of not for prime time language (I was the only one home at the time, so I just let it rip). That situation remedied, I was then looking at an un-centered, in relation to the deck, bow sprit that has a 1/16" gap on the port side and is flush against the deck on starboard. I honestly don’t know if this is Revells fault or mine. The pieces are all in their allocated slots per assembly directions, so I am going to ausage my ego and blame Revell.Anyway, the following pics show my remedy.
I filled in the gap with a piece of scrap basswood and then covered that with a cutting from one of the deck cutouts that, thankfully I saved. As you can see, the mounting tab for the ramp thingy isn’t centered and it is a little bit too far aft to follow the Bluejacket plans exactly.
I didn’t have the right size styrene, so I made the coamings from basswood and used the Bluejacket PE grating.[I finally convinced them to send me the PE set after all. Yeah Bluejacket!] According to the plans, the grating should nearly butt up against the boom, but since that damned mounting tab had to be covered, I ended up making the coaming sides a tetch longer. The bucket is sitting on the part of the tab that sticks out to port. There is still a bit of a gap between the bow sprit and the coaming on the port side, but to do it any other way would have been even uglier. As it is, I can live w/ it.
I haven’t glued anything dow here, and some touch up and dull-coat are in order, but, all in all, much better than that ugly ramp thingy. [painting wood is a whole different animal than painting plastic.In hindsight, I should have sealed the wood with a varnish or something before painting] And yes, the buckets and rope coils are hiding the tab part that still shows, and a couple of scrapes on the decking [more not for prime time language] that I made while paring down the tab. I may just redo this in styrene at some point. I don’t like how ‘bumpy’ the paint finish came out.
Things are going much, much slower w/ the spar deck, so it may be a while before another post.
Axiom: There is no such thing as trash when modeling.
