I have seen several references in the magazine builds to using EZ line. I have searched the hobby links I have but cant find it. What exactly is it, how do I find it? Looks like a great finishing option, if I only had it.
Thanks in advance
Thanks in advance
I never used it,but remember reading some posts on it.Looking to try it out myself.Look here:
I’ve used it on 1/700 carriers. Kinda nice as it’s stretchy so if it gets bumped it (usually) doesnt get popped off. Only problem is it’s not truly round, kinda squarish, but it works.
Don’t remember where I got mine but I got two spools, one of each diameter. Was originally marketed for train layouts because the telephone lines broke easily if bumped.
EJ
I used it or something like it before. I bought a used P-26 off eBay and it came with a PE set and some line which I believe was EZline. It worked well, however it, or whatever I was using, does seem to be susceptible to temperature. I stored the build in the garage and the line slackened off substantially in the cold. I brought the build into room temp and it tightened right up. I pretty much use fly fishing line now.
Paul,
Here’s the URL:
http://www.berkshirejunction.com/
They are great folks. Always a pleasure to deal with them.
I like it
Thank you this is exacly what I needed
no problem
I got EZ Line from Ebay and used it to simulate tying ropes in my roof rack van build.
LY2A2088 by Oscar Baez Soria, on Flickr
LY2A2034 by Oscar Baez Soria, on Flickr
As you can see it has tons of uses and applications! [:D]
A pro- it takes and holds knots better than monofilament.
A con- certain CA glues melt it. Best to test first.
You can split it. I’ve never tried to paint it. It’s dirt cheap.
Super nice van build!
What is the thinnest available? Or, does it only come in one size, and if so, what is size?
This copied from Berkshire Junction site.
EZ line is unbeatable for simulating Telephone and Electric lines, all suspended wires, ropes, fences, etc. This Elastic Polymer will stretch when bumped and instantly go back to it’s original shape. No more re-glueing bumped telephone lines! No fuzz or kinks. Sold in 100 foot (30.5 meters) spools available in natural white or dyed in five different colors. Two sizes are available to accurately simulate both electric lines, telephone cable, or whatever else you may need. Scroll down for pictures of this Berkshire Junction exclusive product - seeing is believing! Looks great in all gauges, depending on the application. Indoor use only.
Recommended for N and HO model railroad scales. This size works well for other models from 1/350 - 1/87 scale.
In some HO and S scale layouts, a mixture of large and small diameters looks best, for example, simulating both telephone cables and electric wires on a pole.
For other scale models, such as model planes and ships, our recommendations are based on what our customers have told us worked for them.
EJ
The fine stuff, at 1/72.
Nice plane GM.
EJ
Hey sorry to pirate the thread but would the fine size work well in 1/700? Or should I use very small fishing line?
I have looked for finer line than that without success for 1:700 work. However, using stuff in any finer size would be a challenge. I find 005 or smaller becomes almost invisible even with fairly high power optical aids. I stopped looking for smaller stuff and am satisified with ez-line and fly tying line now for my 1:700 work. Even so, I need to keep large cards of black and white to prop up behind ship to provide enough contrast- white card for very dark line, black card for the white and tan line.
Sure. 1 last question, how do you attach it to the rig points? Do you tie it or glue it?
I just apply a very small amount of thin CA. For me that usually is enough to hold the line after it dries - in perhaps under a minute. The amount of time it takes for the CA to dry enough to hold the line will vary a bit but the thin stuff usually holds quickly.
As to whether or not to tie the line, well, that depends on the kind of end point called for. Remember that EZ Line stretches and may not act the same as thread or filament so one should experiment a bit before committing to using it on the model.
P.S. To GMorrison: The amount of rigging in the aircraft you posted above would drive me absolutely insane. It’s a wonderful looking plane!
I do both. I like to secure it with a knot or other secure fastening, and then glue it. Now on larger stranded thread the glue may not be fully necessary, but any monofilament style thread really needs the glue- I find these can loosen up soon after tieing. On the other hand, I find line just glued to a small spar very fragile. If the line needs to be attached to a major structure I will at times drill a hole in the structure or large spar and just glue it. Line glued into a drilled hole will be secure without a mechanical termination.
