My first allied tank built about 2 years ago was a Tamiya Sherman… Took it down from the shelf and using everything I’ve learned from the forum, want to redo some weathering, particularly on the tracks… i know with the Stuart variants, the pads are rubberized and wouldn’t show rust or steel… What about the Sherman? would I want steel showing on the chevrons of the track? The rest of the weathering I can figure out, but I’m just looking for some guidance on the track… Thank you so much.
Just had this conversation last night and learned something- some had steel chevrons and some had rubber. The steel ones are much thinner than the rubber one. espins1’s sherman thread has pics of both for you to compare to.
I painted mine black then I took modelmaster panzergrau and mixed a little more black so it was dark and dry brushed it. Finished it off with weathering pastels.
Try this, go to left hand side on FSM webpage. In search box type “Sherman Specifics”. This will take you to a link to a Cookie Sewell article. There, FSM gives PDF article link that explains track types. Good luck.
