Revell/ Takara 1:32, Kawanishi N1K1 Shiden "George"
Hello,
Since there is almost as good as no posting of new W.I.P’s or kits that are finished, I thought that it’s time I’d do something about it…[:D]
At the moment I’m building a 1:32 scale N1K1 Shiden. It’s an old kit made by Revell / Takara , Japan. There is a “story” that the molds for this kit ( and the Revell Raiden, Revell Ki-61 Hien) were lost a sea when the ship that carried them got in a heavy storm and the container went overboard.
I’ve won this kit on ebay for a relative low price, (only €80,- with shipping ) when you take in account that others are sold for twice that amount!.
It’s not my favourite Japanese fighter… but it’s 1:32 scale and Japanese so I HAD TO HAVE IT!
The kit is, considering it’s age, very well designed. It went together very well and the only problems were that it has rivets, which are very well done and small but difficult to reproduce once sanded off, the wing edges were not flush went the halves were glued together.
The pics;
the box
seatbelts made of Evergreen.
the engine,
The wing parts that didn’t seem to fit very well…
the wing/ fuselage needed some putty
masking the canopy, the tape in the corners are to make “round” corners in the window panes.
made new oleos (if that’s what they are called) of Evergreen rods.
Best regards;
Hey Surge,
As allways amazing work!
I never knew Revell made these and that’s some crazy story about that shipping container lol.
I see you try to make curved corners on those windows,
Maybe you allready know but I’ve seen a nice technique to achieve this!
You should paste your tape onto something and then use a little hole puncher (punch and die set) and then you can get some nice even curves, just wanted to let you know!
anyway, it is indeed very quiet in here, hope it will become better during winter,
with regards, Ninetalis.
I have several of the Tonys and Raidens, but I didn’t know they even made this one. I am sure yours will look great when done. Looks like the wing tip shrank a little there.
Looking good Plasticsurgeon!
@ Ninetalis; I have been looking for such device but I’ve never seen one… I have a “gaten-tang” ( Dutch for pliers to make holes in leather, belts etc.) but I find it easier to use a paperpunch of a flower, punch several out of maskingtape and cut the leafs off. And use them for the corners. ( a part of such flower can be seen in the pic.)
She’s comming along nice. I have two of these in 1/48 I havent yet tackled.
I think that only the 1/32 Raiden molds were “lost”… Tend to believe that since I’ve seen a number of Tonys and Georges go for around 30-40 bucks, and around 50-100.00 for collector-kit prices but the Jack, whenever it makes a RARE Ebay appearance, quickly shoots up well past 175.00, and can’t even be found at Old Model Kits DOT com…
If only the Raiden molds were lost…why aren’t there any reissues of the Georges and Tony’s after the early 1980’s? Like Revell did with their Mustangs, Spitfires etc…
I’m looking on e-bay almost everyday for ( japanese WW2 ) kits but I have never seen the Revell 1:32 scale Kawanishi N1K1 Shiden for a starting bid less than $130,-
the Revell Raiden, I had one a couple of years ago, paid €80,- on e-bay with shipping. ( wrecked it when I tried straightening the warped wing with hot water , see:
http://plakkers-inc.nl/viewtopic.php?f=8&t=804 )
And since Hasegawa released their Raiden the Revell ones are sold a lot cheaper. I have seen a couple with starting bids around the $15,-
I just read the Raiden topic in link. Using boiling water an a warped wing was not such a good idea (or, as princess Maxima says “een beetje dom”). But you found that one out the hard way. I hope this build wil go better.
@ Borg; I’ve done it before and got away with it!
But that kit was made of a different kind of plastic. (Even the primer burnt into the plastic and dissolving the rivets…)
The Hasegawa 1/32’s can be found for very good prices on ebay. I’m currently watching two, ones a buy it now. I wonder if it’s the same mold as revell.
http://www.ebay.com/itm/Hasegawa-Japanese-Kawanishi-George-N1K1-Ja-Shiden-Type-11-Koh-model-kit-1-48-/221116152221?pt=Model_Kit_US&hash=item337b8cb99d
I have buid the Hasegwawa Raiden too, it’s not the same as the Revell one,
it’s here on Finescale see;
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/148675.aspx
Just noticed that your link shows a 1:48 scale Shiden kit …
Not much happened lately…I’m a very slow builder and I’m always surprised when people build a couple of planes in the same time that I build only one…
But here is an update;
After I sprayed some primer, I sprayed the preshade, the yellow for the IFF (Tamiya yellow with a drop of red) and the red for the Hinomarus (which is is sprayed on a base coat of yellow). Then I sprayed the panels with blue. To get a blueish sheen to the green. But this was all for nothing because the green completly covered the blue afterwards.
I masked the hinomarus and the IFF with tape. And sprayed the bottom ( Tamiya IJN Grey) and the top (Tamiya IJN Green).After that it is postshaded with the green diluted with a lighter colour of green.And sprayed the edges of the panels again with a mix of IJN green with a few drops of flat black.
When I peeled the masks off the Hinomarus the paint came off and so I had to respray them.
First with yellow and then with red.
After the re-spray;
I have sprayed a gloss clear coat over the plane and put the decals (tailcode and data) on it. This went very well on the left side after a load of Microsol and Revell decal-softener. The right side shows some silvering. Left it that way because when I would remove the decals I think I had to sand and respray the kit, like I had to do with my Raiden.
Have replaced the guns with thin copper tubing and made a pitottube of a coppertube and a sewing needle.
Started with the chipping, used Revell silver and a few tints of Revell green and Tamiya acrylics.
Have to do some work on the chips on the midsection of the fuselage, the chips are not what I hoped for.
Then I put on some washes. A couple of days and then it’s finished…
Bis zum nächsten mal!
As usual beautiful work there PS! And of my favorite Japanese aircraft no less. Strange about the paint peeling up on the hinomaru but great job on fixing it. Love how the chipping came out.
Btw: I’m starting up Imperial Japanese Group Build Part ll on New Year’s Day - would love to have you if you have the time.
Watching one Revell Raiden on Ebay right now with a “Buy it Now” of 79.97… Don’t want it THAT bad…
Question for you (and others) what do you cut the brass tubing with to get a nice clean line (without spurs and crimping?
BTW: The build is looking great.
Try a brand new #11 blade and roll the brass tube scoring as you roll. You may need to clean up the inside of the tube with the blade’s tip. How are you going to flare the cannon’s muzzle? I’ve had paint peel off when using acrylic primer so just wonder if you also used it.
This is my favorite Japanese aircraft. It’s big, massive and looks like a brute . I have 3 in 1/48 scale from Hasegawa and a while back, picked up one in 1/24 scale by Bandai in ebay, factory sealed for $17. It has a complete engine but needs a lot of scratch building in the office and under the hood.
Mini hack-saw and a small bench-vise to hold the brass… Still need to clean up the cut a bit though…
But mostly I use hollow-handle Q-tips for blast tubes… Have to add a wire stiffener for long ones, like on a P-47, but they’re far easier to cut…
Thanks for the replies, I have used the #11 rolling it but boy does it dull things and it has to be cleaned up, let alone trying to flare the tube, yet to figure that out. Hans, I’ve not used the Q-tip but it sounds like a great idea.[;)]
