I thought I’d post some pictures of my build, which is perhaps about 75% complete.
I was planning to put much more effort on it, but ran out of patience - the thing is just too darned small and virtually every part was warped, had flash, sink holes, pin marks, or whatever. It’s OK to remove some flash from time to time, but this was like carving out a model from scratch. In some parts the flash was several times larger than the actual part. Revell should retire these molds and maybe work on a new Victory model, which I’m sure would be a top seller.
I ended up using this as a test bed to learn rigging, using Lennarth Petersson’s wonderful book. This is actually my second ship model, first was the Revell Santa Maria.
Rigging every line at this scale is proving to be extremely challenging; access to the scarce pin rails is almost impossible and I’m including commonly omitted (at this scale) lines like reef tackles and leech lines… there’s just no physical space to belay them all to the right place, so the model ended up full of mistakes, cyanoacrylate blobs and sloppy work. But I believe I will be much more prepared when I attempt something bigger, like the 1/100 from Heller. I’m working on a couple bigger scale ships too, which will be my first attempts at rigging deadeyes and lanyards.
Added to the OOB kit are the shrouds and ratlines (the plastic ones are awful). Ratlines were threaded through shrouds with a long, thin needle. The figurehead, which is moulded flat and is probably the worst part of the kit, was softened up from behind with liquid poly, then bent a bit to better represent the angle of the cherubs on the real thing. Fake hawse holes made from stiffened thread were added (the kit expects you to pass the anchor hawsers through the gammoning slot!). Sails and flags are made from that paper that comes in shoe boxes - the material looks and behaves much like silkspan. By wetting the main course sail and pulling on the bunt and leech lines I managed to somewhat “brail” it. I must give my thanks to jtilley for that idea, which I found in an old forum thread. The fore course sail will receive the same treatment. All sails will be weathered a little more with dilluted acrylic paint, as they look a bit too white right now. Reefs will be added.
None of the spars was replaced, except the dolphin striker and the bowsprit flag pole, both of which broke while handling and had to be replaced with sewing pins.
Blocks are mostly over scale, but that was before I managed to succesfully represent them with knots and white glue.
I’d like to build this kit again in the future, with a simpler rig, but only if I find a vintage, crisply moulded version. Maybe scratchbuild some ornaments and make a Royal Sovereign from it. And perhaps the most important thing I’m learning from this build is to use dilluted white glue for rigging, rather than CA. That stuff is impossible to tame…
Thanks for looking!
