Revell Decals
I’ve just finished my Revell HS 129. The decals are the so-called “Super Decal” as included in the kit, and I found them to be excellent. I used them in conjunction with Micro Set and Sol. They conformed very well with the panel lines and raised detail.
Any else use the “Super Decal” as included in their other kits?
Were they printed by “superscale”? Generally, I toss Revell and monogram decals in the waste bin unless they are printed by a different decal company ie: superscale, microscale etc…
The kits decals are usually thick, and colors are off a bit so I end up replacing them. Hasegawa is probably the only kit manuf. that I would consider using the kit decals.
The only clue I have as to the makers of the ‘Super Decal’ is printed on the bottom of the sheet - Made in Italy by Revell AG.
The decals labelled "super decal"are often very good. If they are made in italy they could be printed by cartograf.
My next Revell aircraft kit is the Me 410. I’ll certainly be using the kit ‘Super Decals’.
