Bullitt is one of my favorite movies, so I was really excited to find the Revell kit in my hobby store. Normally I build Aircraft, and cars are really out of my zone. I’ve tried building it twice but to no avail. I’m really stuck on the green color. The first time I tried painting the body, I used a few different Enamel paints. mixing them together, and on their own. They looked pretty good, but I never got that Green in the movie. So I tried making a Metallic green out of Tamiya Acrylics, though this did work it still didn’t get the correct shade. According to Ford, they Green they used is called “Highland Green” I’ve seen a few pictures of this paint online here and am not really satisfied this is the same color.
I even went to and automotive paint store, they said they could get it. And that it would be pricey, since its a rarer paint. Plus I didn’t want to have the plastic melt from a can of car paint. I know one paint company used to make it for models. But they don’t produce it, and they don’t Ship to Canada. I’ve almost given up and gone for Tamiya “British Racing Green” But wondered if anyone here had any idea’s
What makes you think Automotive paint will melt Plastic? Maybe if you soaked it in pure Lacquer. That color should be Enamel for that year. See if they will sell you a half pint and use an air brush to paint. Get your self a scuff pad, scuff the model, put a dust coat on, let set, another dust coat, let dry and then final coat.
Been painting real size cars and trucks all my life. Antique car collector. I’m only 72.
I heard from a few modelers not to use automotive spray paints on styrene. Personally I’ve never tried it, like I mentioned I’ve never really built a car before, so I’m a rookie to all this ha ha. But would it also be too thick for a model?
You can use automotive paint; but you have to be very careful to prime the body properly with a quality automotive primer, or the paint will eat the plastic. You should experiment with a junk car body that you won’t mind messing up in order to get a feel for it. The thickness of the paint won’t be a problem.
I’m having a slight problem understanding this comment. The thinner used, for the Primer, is the same that is used for the paint. The plastic is made with Petroleum products and so is the paint and primer. Should I expect my two corvette’s that I painted three year’s ago to melt, eventually? The fiberglass after all is another mixture of plastic resin’s with Petroleum products. I think a lot of people are confusing solvent based paints, with the old Floquil paint that would attack the plastic slightly, if brushed on, not sprayed on. One of my Grandson’s, for the past year, continues, to play with a Tamiya 1/14 scale RC truck, that I painted with nothing but Automotive paint. Silver base coat and Metallic Blue over it. If you give it a couple of dust coats first, you won’t have any problem’s. As the OP mentioned, he is new and probably does not have an air brush, which would be ideal. So he should practice on some scrap, with a rattle can spray, for they do put out more paint, for model painting.
A suggestion: What ever paint you decide on. Try a little experiment, to get the color right. On some white shirt cardboard, spray an area with gray primer and then spray the color you want over it. Now on another piece of white cardboard, spray black primer and then the color you want. After drying, compare the two colors. I’m guessing the color you want of the Mustang, will look like the one you primed with the black. I have seen the color in person and it is rather deep looking. Have Fun! But practice.
Sorry, I was talking about the automotive primer out of the spray can, like Duplicolor. I’ve seen modeler’s builds in “Scale Auto Enthusiast” that used it that way with no ill effects.
