Revell '64 Ford Fairlane Street Machine 2' N 1 Kit 85-2076 1:25 Scale
This is a kit that I picked up a couple of years ago, and started working on. I did the logical thing and painted as many of the pieces that I could while they were still attached to the sprue. And then started with step one which is not only building the engine but deciding if it is going to be an automatic or a manual transmission.
I opted to go with the manual transmission. And right now all I can say is that I am glad that I have dry-fitted the parts. As sadly, not all of the pictures are totally clear as to which order some of the parts should be attached. And only through dry fitting was I able to figure out what order to attach the parts. I am down to attaching the fan, fan belt and alternator.
Then I get to attach the engine block to the chassis, as well as moving on to attaching the various parts to the chassis, and so on and so on and so forth.
Obviously being a 2’ N 1 kit, there are going to be pieces that one is not going to use in the build, those can be used in another build, or as “decoration” in a garage diorama. That being said, I have noticed that so far there are at least two pieces that are not shown being used. One is a hood with a teardrop scoop on it, and the other is a hose of some sort that is numbered 49 on the sprue. I am going to paint that flat black and again save it either for use in another build, or to be used as “decoration” in a garage diorama. Likewise, I am going to save the “plain” hood to either use in another build, or to use as “decoration” in a garage diorama.
So far over all I’ve gotta say that I do like the kit and am impressed with the detail. The instructions could be a little clearer as if an adult is “confused” as to the order that some of the parts should be attached I can see a “child” being equally confused. I would like to add that of late I am less then impressed with Revell’s customer service. If one has a lost or damaged part one has to either submit a replacement request in writing either via snail mail, or online, they no longer do replacement over the phone. And they only provide “technical” support on Monday, Wednesday, and Friday, and more often then not one is prompted to leave their name, phone number, and a brief description of the issue for a call back presumably later in the day.
I do have a couple of questions. When attaching the fan to the fan belt should it be glued in place, or just pushed into the hole? The paint chart did NOT mention chrome paint, but in the instructions when it comes to the steering wheel it says that horn band is chrome and the rest is black. Wouldn’t it have been “easier” to plate the steering wheel chrome and then have the builder paint the rest black? I’ve also noticed that while the box lists flat black as one of the paints needed to finish the kit, it however is NOT listed on the instruction sheet. And I will give Revell credit in that other then metallic blue there are no “exotic” color paints listed to finish the build.
The fan belt is usually made of rubber in a real car,…so that would be flat black
I would glue the fan in place,…I would hate to have that fall out.
Have fun with the build ,…and hey,…show us some pics!
Cheers
That’s the color that the fan belt is. I was talking about both the fan and the steering wheel. Its painted gloss black and the horn band is listed as being chrome.
I have to admit that that is the way that I was leaning. And as I’ve said, thanks to dry fitting I was able to get the right order to attach the various pieces to the engine. And I won’t say that the engine is super-detailed, but it IS very detailed. The whole kit is as there are 127 parts in it.
However, I am going to have to put the build on hold, as when I was looking at the fan as it was attached to the chromed sprue I noticed that one of the blades was broken. So I’ve contacted Revell about getting a replacement.
Question, is it better to paint the interior compartment as well as the rear deck, or to flock it? I’m thinking of flocking it, as wouldn’t that be more realistic then painting it? And on a kind of related note, what is a good source for license plate decals for all of the states. Florida in particular?
