I finished the ship last year and turely enjoyed building her. I have been proudly displaying her along the stairs leading up the the house loft.
The other day my dog(Marley) was chasing my cat(Oscar). Oscar chose to turn left and leaped through the hand railing landing directly on top of the ship. Oscar is fine but I can’t say the model faired well. I was heartbroken but I’ll be fine too. Just thought I’d share the experience.
Brucer, I am so very sorry for you. In the past I put all my models in cases or cabinets, but with my last big bunch of sailing ships, they are all on shelves. We are thankfully very old & have no grandchildren close by & they are all grown. Only 1 old fat cat, who is no trouble.
I have over 150 1/48 fighter planes all highly detailed & in glass cases. 7 or more wood ship models ,in cases & 160 cars of all types in cases Right now I have at least 20 sailing ships & more WW2 ships.
Holy S**t!!! I was expecting a missing rat line or something. I was actually looking at the first pic trying to figure out what got damaged… then scrolled down - what a disaster! Not to pile on you’re misery but I fired off the explicatives and then laughed a bit (you have to) as I am an animal lover and have lost a couple parts/builds to my 4 legged friends. Sorry brother - what a massive cat bomb.
What a tragedy. Mine survided two moves, but was knocked off a shelf during our third move. Equally as bad, damage wise. Ended up in the bin, since we had a newborn and zero time to even attempt a fix.
Hope the cat is Ok. Could have easily been impaled by one of the masts.
I had a similar experience with a wood Model Shipways Cutty Sark.
I was able to pretty much restore it. I suggest you sit down with a glass of wine and look at it carefully. I’ll bet that the breaks are few, masts at the deck, a couple of the lower yards.
Think about the old “ship in a bottle”. If you are able it all should be able to be sort of stood back up again.
The result is a little different than the original, but I suspect you who have really good detail skills, can get it to work.
A Catacaine can be a devastating thing for a sailing ship. Now, Thing is .If the rigging lines stayed attached you can start remasting her. Just take your time and don’t get mad at the Cat . She was doing what her instinct told her .A high and somewhat flat place.OOPS ! ! what’s thing I just broke?
I took a second, more intense look . Though the damage isn’t light ,she can be re-rigged .
Brucer, blame the dog, he was doing the chaseing. I have fixed a lot of broken pastic with an assortment of aluminum tube & rod & a big assortment of wood dowels. Fit them in each side of the broken mast & CA glue them in good. I also use a bunch of brass rod too. When I build any plastic ship I put alum, brass or wood inside of the hollow masts.
I like aluminum better than brass because it is easier to work with. I just broke the plastic bowsprit on my big Victory, twice & just cut it off & replaced the 2 front pieces with alum. tube with a brass rod inside.I also on solid masts, drill a hole in each side for a brass rod & fit & glue them together. Stronger than new.
You have a beautiful detailed hull all done so it is worth fixing. Buy a bunch of sizes in all the rods & tubes & dowels, you will use them forever. I am 88, & still building & still breaking. A real good friend of mine is one of the top model builders in the country, or world & he had a finished Titanic sinking to enter in the Tokyo Tamiya contest ( which he has one several times & a bunch of firsts) & his CAT knocked it of the bench. He took it to Tokyo anyway & won some disaster award first place.
Definitely do your best to fix it. It may be possible to reattach the masts, and if careful to save some rigging. Otherwise, like Gene said, get some rod and dowels. This model is worth fixing.
You can’t fault the cat who “plays” with your rigging.
If you’re not up to the task of rebuilding all the masts and rigging, you could replace it all with a stub wooden mast, in the style of an Admiralty model. There is a lot of great work in that hull, after all!
Side question: It looks like the model has molded plastic ratlines- does the 1/96 scale kit come with those now? Or is this a photo of a fabulous build of the 1/196 scale kit???
Man, that is terrible, what a beautiful model you built. Clearly a ton of work went into it.
Yeah, pets and models don’t mix. I am babysitting a cat and i moved everything out of reach.
It’s probably fixable, if so inclined. If not, you can keep it displayed as a ship devastated by a tempest that blew in. Could be a great conversation piece.
Major Bummer [:(] That would be difficult to fix because the rigging looks to be all tangled. I guess that you could remove the rigging, fix the masts and redo the rigging.
Perhaps, a diorama of the CONSTITUTION in drydock as she appeared in a recent series of restoration in Boston. All the rigging would be avoided as she is shown with masts stubs.
As dishearting as the situtation appears, don’t give up.
Maybe, but I’ve done a few of these. You want to sort of “un-recreate” the accident. It was a cat falling on it. Figure out where it landed (on the top). Visualize the cat lifting back into space and the spars and ropes standing back up. These things are usually smashed flat, but not tangled.
The ones I’ve fixed all toppled over from a shelf and hit the floor upside down. Kind of the same.
Then…Get it to your work table and insure no pets can get near it. Maybe build a lightweight jig from from dowels or wood pieces that is bigger than the ship. That way you can very carfully start picking up the parts and possibly tying them or taping them to the jig/frame I’m talking about. Then you could assess the damage more clearly. Maybe glue the masts back using a plastic welder like Tenax, then go from there. I think you could go a long way towards fixing this, but your mind has to be in the right place first.
Good luck
I have purposely not rigged my Revell 1/96 Cutty Sark because I don’t have a case.
