Revell 1/72 Sea King
Started on this heli yesterday.
It’s the Revell 41st anniversary kit, I bought it when I was looking for parts to spruce up my Jolly Green, and I was getting impatient whilst waiting for a Fujimi SH-3 kit to arrive. I ended up using the Fujimi kit as a donor for parts for the Jolly Green and this one has remained in it’s box untouched, until yesterday. I could probably build the Fujimi SH-3 also but it’d be missing a cockpit interior, I can use the main rotor from the Jolly Green, or swap it back for the one I borrowed from the Fujimi SH-3, and the ice shield from this Revell kit as those were the only parts I used from the Fujimi SH-3…
It’s been an easy kit to build so far, and it’s nearly finished in terms of building it, only took me 3-4 hours yesterday. Just need to grind/file off the air defense port thingies on the rear of the fuselage (that thing just behind the big door on one side) and add some vanes and stuff to it. I want to use my dremel to do that, on slow speed, but I’m also a little hesitant over doing so as I I’m wary of overdoing it and going through the plastic, or obscuring more detail than necessary…
I’ve been held up by lack of matt black paint though, if I had it yesterday I could have sprayed the interior, put the windows in and coated them with future ready for masking with Eduard masks, sealed the fuselage up and added all the little vanes and bits and glued the radome on and the model would be ready for painting…
I’m not 100% sure of what extra parts to use (like the vanes on the underside) as apparently you can make many variants of the Sea King with this kit and I don’t know which variant the RAF SAR Sea Kings are generally so I’ll be making this as an approximation with oob parts - I’m not a rivet counter.
I’ll be painting this as an RAF SAR heli, so it should be nice and easy, spray white (maybe over a grey primer), then yellow (I bought the correct yellow when I bought the kit). I have the decals from the Airfix RAF SAR heli to use on this bird.
And this one will look much better than the ESCI UH-1D and HH-3E Jolly Green than I’ve done (well almost done the HH-3E) because I’m sealing it up, instead of trying to magnetise the two halves of the fuselage so I can put in some mechanical parts - financial road blocks have meant I don’t even have those parts and I’m unlikely to either…
The floor of the interior is a bit warped unfortunately, can’t recall if it came like that but over the last year it’s obviously ended up like that in the box. Hopefully I can do something about that when I glue it into the fuselage.
Only bit of “custom” work I’ve done on this helo is to cut out the furthest aft windows so I can put in the bubble windows as per RAF SAR birds. Very easily done and I was surprised I didn’t mess it up - just took a 2mm drill, drilled some holes in each corner, cut with a knife between the holes and then filed the plastic so it’s square. Upon initial test fitting of the bubble windows they do seem a little more recessed than the other windows but they should look fine.
I’ve left the wheels off on purpose btw, just in case anyone is wondering. I found with my Jolly Green on Sunday that I should not have attached the wheels as it made painting the struts they go onto more difficult. The wheels will be painted on the sprue, clipped off, refinished in the spots where they were attached to the sprue and then glued on when I’ve painted the rest of the undercarriage.
Nice work so far, will follow this build with interest.
Well I did some more of it yesterday evening and today…
…I’ve painted the interior including the cockpit and some other detail parts (radome, main and rear rotors, inside of the big door which is currently separate) matt black. I’ll probably be sealing up the big door or leaving it only half open so you won’t really be able to see the inside, so no real point in me detailing it in my opinion.
Almost had a nightmare when sealing up the fuselage though, because…
…I forgot to add the windows! Then on the 2nd attempt at sealing the fuselage I forgot to add the spindles for the main and rear rotors!! Doh!!!
Got all those in though and the fuselage is sealed up nicely now - this kit has a really nice fit, even the slightly warped interior floor fitted in nicely.
Anyway no pics as yet, I may take some on Saturday when I next do some work on this bird before I do anything, but at the moment I’m waiting for the future on the windows and canopy to cure so that I mask them off ready to apply Mr Surfacer on the seams and then overall spraying of white and then yellow for the main colours.
So, I said I’d take some pics of the painted interior and assembled fuselage, before I continued…
…and I forgot to.
Anyway, here’s some quick pics of how this helo looks now after filling seams and undercoating in white -
The “barn door” is sealed up. I was worried about getting white inside the interior and I couldn’t figure an 1d10t-proof way of masking the gap…
I am not overly happy with my seam/gap filling. I seem to be unable to get a nice smooth finish to my layering of Mr Surfacer 1000, primarily because I’m worried about destroying detail around the Mr Surfacer. It’s most noticeable around the top of the dog house at the back and at the front around the engine intakes.
I’m also not happy with the Eduard masks I bought. The canopy masks don’t seem to fit properly, some parts seem too big, some parts seem too small and one of the side window masks was also too small. I thought as they state they are for a Revell 1/72 Sea King they’d fit perfectly!!
Anyhow I can probably tidy up the frame on the canopy once I’ve removed the masks…
Can’t do anymore today as the Vallejo Model Air white I’ve used as undercoat seems to be still tacky so I’ll leave it overnight to cure and attack this with yellow tomorrow.
Had a stab at the yellow today. It needs a couple more layers I think because it doesn’t look all that even to me, there’s light patches and dark patches and I can’t seem to get a decent even coat…
…anyway I’ll leave you guys to decide, perhaps a couple of layers of future (I plan on leaving it gloss btw) and the detail painting will bring it all together…
Had one of these fly over my house today so I know the yellow I’ve used looks quite close to the real thing. [H]
I have just realised that I’ve left off the little bits for the aerial on the left hand side (right hand if you’re looking at the helicopter from the front), and also the strip (whatever that is) along the top of the tail boom on the left side.
Some also may notice I’ve not filed/cut/ground off the German air defence ports just aft of the “barn door” and the corresponding point on the other side - I wimped out. I’m not confident of making a good job of removing those so they’ll stay. As mentioned before it’s a bit of a “bitsa” heli anyway because I’ve seen so many photos of RAF SAR Sea Kings and they all look different and there’s so many extra bits in the kit I don’t know exactly what to use…
Here’s some more quick pics of progress -
That sure is yellow . Keep it coming
Rick
Are the “sink marks” on the strut, going to the sponson, supposed to be there? I’m not real familiar with these aircraft, so just asking. Good going so far. Bob
Nice start. I worked with these guys a few times down in the Falkland’s, unfortunately I lost most of my pics recently, I only have one left of one of these, I think even the RAF’s Sea Kings vary on the arrangement of antennas.
Look forward to seeing more.
Hadn’t noticed that. Only seems to be on the left hand one, not the other. Might not be too late to fill it over I guess…
It all went a bit wrong this weekend…
The yellow has some fluff/dust which got stuck into the main coat and won’t come off. The canopy is a bit of a mess, likewise the sandbox. The black mask around the exhausts went all wrong, it leaked under my mask tape and my attempt to clean it up was unsuccessful! Some of the Airfix decals didn’t quite fit and a couple broke up!
This is the last yellow helo I do!!!
Nice to see another Yellow Peril done - well done, nice job!
XZ585 was one of the RAF SAR birds that frequented the hill’s around where I’m at & unfortunately ended up being bent in a training exercise about 15 miles away (1989);
It’s not all bad news though as she was rebuilt, here she is in 2010;
Thanks. I’m not at all happy with this build though. What I thought would be a nice easy build, actually turned into a bit of a nightmare.
Basically after assembling this helo which was nice and easy, and getting on the first couple of coats of yellow, nothing went right.
It doesn’t look so bad in the photos, and it doesn’t look so bad when viewed from a distance, but up close it looks terrible. I’m actually more impressed by my HH-3E Jolly Green Giant!!
I can only hope my next build (a continuation of my UH-1C, and/or finishing my Bell 47 USCG off) goes better, and then after that I have a build that should look good and be easy - an Italeri 1/72 MH-47E, at least it will be 99% black, I can’t go wrong with that…
