I’m here with more plastic to mash. I picked up this kit at a recent model swap meet, figuring it’d be a fun change of pace. I didn’t plan on starting it until after my wicked of Omars was further along, but after fighting with the complexity of the HB and Hasegawa Hornets, I cracked this one open to keep the fun flowing.
I decided to start with the wings.
Then I moved to the forward fuselage. There must be different boxings of this kit because the fuselage and nose are molded separately. I didn’t get a photo of them separated, but the instructions call for having the assembled nose attached to the assemble main fuselage. I attached the nose halves to their corresponding fuselage halves to help with the seam. Things went together very well. (Sorry, no photos.) After that, I decided to do something about the nose guns.
I didn’t want to break the barrels or deal with them during painting. So I cut off the barrels and drilled out the gun body to receive them later.
I used some CA to attach the gun bodies to the fuselage halves…
And it all allows me to slide the barrel into the body from the outside.
More than anything, this was a proof of concept for an idea I want to use on some old Revellogram 1/48 WWII bombers I have in the stash.
So this one will be my go-to when glue or putty or paint are drying on my Omars. I’ll be sure to post more when there’s more to post. Until then, Feel free to drop your two cents into the bucket on your way out. Comments, questions, and criticisms are always welcome. Thanks for stopping by!
Hello fellow plastic mashers, I’m back with an update on my Ventura. First, thanks for all the comments. I appreciate your feedback!
This kit went together very nicely. There are few parts, but they fit together very well. I got the cockpit built up an installed. I didn’t spend a lot of time on it since little is visible through the canopy.
I also got the fuselage closed up. The fit on this kit is excellent. I didn’t need any filler, except in one place.
The only spot that needed filler was a gap between the bomb bay doors.
If you’re building this kit with its bay open, then this area wouldn’t be a problem. I simply slipped a piece of styrene sheet in there to close things up.
Primer followed.
Then paint. I didn’t want to do the usual blue-blue-white scheme, so I went with the Scheme 1 ASW scheme.
Here are the major assemblies dry-fitted together.
To add a little color, I think I’m going to use national insignia with the red surround.
I also got the the engines painted up. Again, not too much effort here since not too much will be seen.
So that’s where things stand with my Ventura. School starts this week, so progress on this and my Omars will slow down. Of course, I’ll post more when there’s more to post. In the meantime, comments, questions, and criticisms are welcome. Feel free to drop your two cents into the bucket on your way out. Thanks for stopping by!
