Closed up, and wings on. Yes I still make tape monsters, lol.
Fit is not that great, which I kind of expected. Fortunately it’s a small plane, so it shouldn’t take a ton of effort to take care of the seams, and gaps.
Oh this should be a good, entertaining thread. I’m sure many of us have this kit in the stash besides myself.
I have been quietly working on the old Monogram “Miss Detroit” boxing I finally found in Portland a few years back. The parts fit isn’t perfect, but it is a sharper molding.
However the Revell kit you have has some amazing markings in that box! I was impressed with that. If you go with the box art scheme be aware that the solid black tail is actually also black and white checkers if you want the accuracy.
With enough elbow grease this kit will still shine brightly. Just be mindful of all of the gaps lol.
Greg, yep I will be using the kit decals. I might just paint the checkers on though, as Mike has suggested below, lol. I’ve never painted checkers, but those decals make me nervous.
Mike, I haven’t seen any pictures with the tail being checkered, but I did notice the wing tips are checkered, and the decals give are just stripes. All the pics I’ve seen online just show the tail being black. There were several planes painted with the scheme, only older picture I seen of the original bird you couldn’t see the tail.
Shipwreck, fingers crossed!
cbaltrin, I got the two markings to pic from, and I just don’t care for the weird two toned, green over natural metal look. Besides, red and black go together so well!
Was just looking, and came across an article from 2016 in sofrep, fightersweep. They gave a rundown on the original, as well as markings replicas in honor. The article makes no mention of the wintips, but did say the rudder was all black. There is a picture of ground crew checking the plane with prop turning that you can see the bottom and top of the rudder, no apparent checkerboard. No to say they didn’t change later.
Nothing definitive, but a start if someone wants to dig.
Have the old airfix 1/24 in the stash to build someday, I hope
goldhammer, thanks for the info. I’ll just do the wing tips and the cowling. I have some thin tape, and it looks to just be a bit time consuming placing tape, but probably a technique I should add to the basket!
Mike, Something about the yellow and green together that makes me go yuck, lol. Red and black always catches my eye though, something about the combo.
It’s a nice kit, and when Monogram released it, it was cutting-edge. Revell had its own 1/48 P-51D, but that didn’t make it into the merged catalog. I never got to build it back then, but I’ve got one now, and the Monogram kit, and I’m going to build them side-by-side, to compare how each company dealt with the subject.
Hey, Keyda. I was messing around with my 'Stang and I ran into a problem with the nose pieces not fitting flush. Thought you might want a heads up if you haven’t already figured this one out.
I had to use some card stock as spacers to eliminate the poor fit. It all lines up if you do.
Mike Lifelike Decals makes a BBD history sheet. All five schemes of BBD are done. Always had a black tail but two schemes were different. I really want this sheet
the Baron, it does look like it was pretty fancy when it first came out in 1977, lol. Compared to some kits I’ve seen from roughly the same time frame it really isn’t too bad.
Mike, I’m glad you mentioned that, cause I went and checked my pieces. Only issue I had was the one piece was missing a big chunk. So I had to install it, and put some filler in there.
tempestjohnny, that sheet is available from 1001modelkits.com, said it was in stock.
Past couple of days have been spent doing the putty, sand, prime, repeat, which just makes my tennis elbow flare up, lol.
First coat of primer, wasn’t looking too shabby, but I did a few more rounds.
First coat of gloss black in prep for the AK extreme metal paint. Never tried it before, so fingers crossed.
I landed up doing a bit more sanding as the black brought out all the imperections, and some I just couldn’t live with. There are still some, but I’m going to leave it as is. Soon as I get too picky things will take a turn for the worse, and I’ll really screw something up. Hoping to get paint on it tomorrow!
I’m surprised you didn’t attach the forward nose piece. You’ll have to putty the piece in to blend it to the rest of the nose.
If you go back to my picture you’ll see I used melted sprue so I can scribe those panels in. The nose on this kit is almost as bad as the P-40B. I’m finding I have to be very careful how I plan my assembly.
I have the propeller hub assembly as a separate piece and I had to thicken the shaft so if fits by friction so I could get that nose all solidified.
The nose piece was listed further along in the instructions, so I hadn’t paid attention to it at the time. I did install it, and used some putty to fill in the missing chunk. I sanded down the main seam along the nose, even though there is a natural seam line there. It was looking pretty bad. Then I just scribed a line down the middle, and used a pointed scribe tool to add screw heads back in along either side of the panel line.
If Mike hadn’t mentioned it, it would likely have gone unnoticed until later on, and I would of been swearing about it, lol.
Got quite a bit of painting done today. I also did a little experiment. Glad I did. Painted with AK Extreme Metal Polished Aluminum. My first time trying the stuff.
I wondered what affect clear gloss would have on the finish, so I opted to paint the scoop that goes underneath with a quick coat of gloss, the results were not good.
Compared to the plane you can clearly see it turned the paint into a shade of gray.
So I opted to test out what Model Master Metalizer sealer does. The drop tank on the left is just the metal paint, the one on the right is with MM metalizer sealer, and the scoop with Testor’s gloss clear.
I will have to use the metalizer sealer on top of the decals. I’m glad something works without totally messing up the finish. There is a slight difference, but I’m okay with it.
So once I figured all that out it was time to mask off for a bunch of stuff, checkered wing tips, black tail, wing root walk ways, and the OD anti-glare.
Halfway through the checkers.
All done for the night. I am going to have some touch ups, and I’ll need to paint some very thin red lines in a few places, but that is for tomorrow. With any luck I’ll be done before the weekend.
