Hey gang,
I’m coming at you with something I’ve never tried before. The other day, my wife was walking her dog and ran across a yard sale that was selling some kits. Spending $2, she was able to get me a Monogram A-4 and Skyraider, two started Testors SR-71s, and one started Revellogram Razorback. The Skyhawk and Skyraider are complete but without decals or instructions. The Blackbirds are started and appear complete, but are missing the instructions. The Thunderbolt is started, but missing its instructions, decals, and the tailwheel. Also, the guns’ blast tubes and radio mast are broken off. As something to distract me from the Hasegawa AH-64D slog I’m currently involved with, I thought I’d try to salvage the Thunderbolt.
It came loose, in a box filled with parts for the two Blackbirds.
I was able to get the parts sorted, and like I said, it appears that only the tailwheel is the only missing part besides the broken blast tubes and antenna.
I think the prop is from a different kit because the plastic seems to be different, and it doesn’t fit on the prop shaft. It’s really not going to make a difference. I won’t be going for 100% accuracy with this build.
The canopy was attached and unfortunately had a glue smear on the inner surface. Also, the panels behind the pilot were painted. I thought about prying off the canopy to repair the mar and repaint the panels, but I decided against it. I didn’t want to risk damaging the clear parts. Since I’m just going to be using this kit as an opportunity to practice some building and painting techniques, I figured trying to repaint or match the panels wasn’t worth it, either. So, with that, I cleaned up the seams, masked the canopy, and sanded off Revellogram’s infamous raised copyright “stamp.”
To check my work, the parts got primed in Mr. Surfacer 1500 black. I noticed that some panel lines were sanded off during construction, but I’m not going to worry about them.
After that, I started with the upper surface color of OD. After that dries, I’ll do the NG undersides.
Anyway, this is where I’m at with this. I’ll be going back and forth between my Apache and this project. Since this is more of a “practice kit,” I expect this one to go pretty fast. Still, comments, questions, and criticisms are welcome. Feel free to drop you two cents into the bucket on your way out.
Thanks for lookin’. Stay tuned!
-O
