Hey all; I am a relatively new hand at the “modeling arts”…new meaning it’s been only a couple years since I began. I still am pretty casual about it, but getting much better. Supplies are limited around here, but at least I have a background that involves art, painting, and improvising. =)
My issue at the moment is, as the title says, the instruction for a Revell Corsair kit that I bought a year or two ago…I put off building it, since it is very complex compared to the others I have done, with folding wings and landing gear, etc. And somewhere, some time since then, the instruction sheets have disappeared. Luckily, I still have the decals, but I’m nervous about the idea of trying to “play it by ear”…there are a lot of little bits and pieces that aren’t really obvious as to where they are supposed to go, and how they’re supposed to get there and in what order. I probably could pile it together well enough as a “basic” (non-articulating) model, but I was kind of looking forwards to being able to display it “gear down” at times…I never build models gear-down, even when they’re designed to be built that way (which can be tricky…they seem pretty liberal with the actual size of the gear doors and wells, etc…I guess “looks close enough” is good enough.
But that’s neither here nor there…does anyone know where or how I can get my hands on the instructions for the kit? I found this forum doing a Google search; there is at least one other thread on here about the same model. The number on the box is “85-5248”. And there’s also the numbers “7058” ink-stamped on the inside of the box lid. I’m not sure what the significance of that is. The scale is (nominally) 1:48, it’s an F4U-4 with Korean War markings (I can’t recall which units…the picture on the box shows the tail-code “MR” and there’s a large number “14” under the cockpit, and it says “Marines” on the side. And if the thread I saw is correct, it includes a radome that is not intended for use on this model (although it has interesting possibilities…I’ve never built a night-fighter before). Yeah, and it has retractable landing-gear, folding wings, and HVAR’s under each outer wing panel. And four 20mm’s instead of the six .50cals (presumably US “M3” electric ignition Hispano-copies). I like that bit the best, personally. Weapons are one of my other hobbies.
So, does anyone know anything that might help me out? Instructions would be nice, but even if someone has built the kit before and could give me a quick rundown on which little pieces go where, it would be great. Thanks in advance if you can help. And if not, then you can just go and…have a nice day LOL, seriously.
