Heya all,
As I said in my introduction post, I am a returning modeler, now retired and hoping to have a go again at making some models like I used to do in the dim and distant past. I have noticed that the standards have gone up a long way now, far better than what I used to turn out back then, so I am a bit hesitant to show my work. Still, the best way to improve is to just get on with it, do one’s best and take criticism on board!
So here we go. My first kit is a small ship by Heller, what they call the ‘Corsair’. Apparently this is based on an existing model of a so called Tartane, a small ship from the Mediterranean. I think I spot some Arabic influences in the shape of the stern?
This is the box art:
This is a cheap and simple beginners kit at scale 1/150, so good practice material. I am not aiming at perfect accuracy but more at an overal impression. I am making some changes as I go along to (hopefully) improve on the basc kit a little bit.
Here are the hull halves after initial painting. I don’t have an airbrush so this is brush work, before any detailing and weathering.
The bare hull, with some weathering. I use oil washes over a base coat of acrylic. I would like to show the deck planking a bit more clearly but am not sure how to do that - they are raised, not inscribed, so a wash doesn’t really work very well. Perhaps I should have put on a black base coat, then a wood coloured coat followed by some very gentle sanding to bring out the planks?
A bit further on, the hull is now almost complete with details. In the kit the inside of the bulwarks are plain, I have tried to improve on that by adding an impression of the frames using plastic card. I also drilled a hole for the anchor line in the deck and the bulwark, and added some more belaying points for the rigging.
The guns are still loose, they are tiny and I am not sure I am up to rigging them in. As they say, when in doubt, leave it out?
Next up is stepping the masts and then some rigging. The rigging diagram in the kit is way too simple and I want to go a bit beyond that. I don’t like the plastic sails and will leave them off, which simplifies the rigging of course. I bought some small wooden blocks, there isn’t a lot in the kit. I’m not actually sure about the shrouds, as far as I can tell these small vessels didn’t have deadeyes and lanyards, perhaps someone in the know can enlighten me?
Jur
