Spent weeks on a diarama, it looked great. Bought a “beginner” 1:1 casting resin kit that had good reviews on Amazon. Followed directions to a T. Looked great when I poured it in but has it cured the bottom was a mess of bubbles and clouds that I couldn’t pop as the top layer had stiffened. Destroyed it.
Would love some help/advice, I don’t want to give up on my concept. Bad brand of resin? Is a quarter inch too much of a layer? I have no idea why it was a diaster.
It was a mix of plaster and sawdust…airbrushed w/ acrylic and some pigments put over the top. Have done a little snooping around since my post and it seems part of my problem was not doing several layers of no more than 1/8 inch thick?
Do I need to seal it too? You may have just saved me from another disaster.
I think the problem is the pour. It really has to be a series of thin layers. Also there can’t be any bubbles in the resin when you pour it. Even tiny ones- they won’t go away.
Other problems are heat as it cures, and shrinkage. Assuming you are modeling a pond or something similar, plan to dress up the edge of the water with ground cover once it has fully cured.
I wouldn’t try to create a depth of more than 1/4" or so. Anything beyond that usually is best done with a piece of glass.
A river bank, using foam as the base with plaster/sawdust as the ground material. Airbrushed it and then used pigments…looked good. The earlier suggestion to seal the river bed is probably a good idea. I assume some clear coat would do the trick.
He mixes a 1:1 clear resin, carefully to avoid introducing bubbles. He pours in a thin layer. Depth is accomplished by judicious painting. He goes over the resin before it begins to harden with a pencil torch. This brings any bubbles to the surface where they pop.
Your problem is that you poured too deep. Resin hardening is a exothermic reaction - that means it generated heat. Too much resin will warp the substrate
