Reptile belly painting
Hi. This is my first post, and I’m a novice model builder, so please be patient with me.
I’m painting a model of a dragon, and I want to paint the belly and underside of the dragon a pale color, like many reptiles have. This is what I have so far:
http://www.linuxfromscratch.org/~robert/dragon/dragon-20110623.jpg
And this is the inspiration:
http://www.spawn.com/toys/horror/dragons/eternal/images/dragons_eternal_photo_01_dp.jpg
Airbrushing this color would probably be ideal. I have an air brush, but this model is small (4 inches tall), and the masking job would be a lot of work, so I’m brushing it. My question is what technique can I use to merge the two colors at the edge, so it looks natural and not painted. I’m thinking to dry brush the edges, where the yellow meets the green. This is a particular problem on the belly of the dragon.
Thanks for any input.
First, hello ashes, welcome to the forums, glad to have you with us
Now, as far as your question… I would say to use your airbrush to blend the belly and the sides of the reptile. You would not want to mask (i.e., hard edge), you would want a nice soft edge / blend. This should be right up your airbrushes alley. Even at 4 inches tall, you should still be able to put a nice soft edge on the belly / sides.
The other alternative would be to blend / drybrush, or a combination of drybrushing and mottling along the sides / belly
Best of luck
Bill
Hello ashes!
The surface is most likely rough to simulate scales. A sponge that is almost dry with paint in a dabbing motion will blend along with dry brushing to smooth it out.
Practice on something with a bit of texture first. A primed piece of wood will allow you to try the techniques before committing to your Dragon.
Take some pictures, if not to post they do help you improve & remember techniques.
