Some paint and primer peeled off when I removed masking tape.
I reapplied primer and paint over the bare plastic but I can still see a “ledge” border between the original coats and the repair coats. Thought applying the same layers again to the bare plastic spot would even it out but nope.
Any tips on how to repaint a bare patch and have it invisibly level with the surrounding original coats?
It doesn’t totally make sense because if you paint two layers back on, shouldn’t it be even? Or is it because the original paint is getting two more layers as well?
You’re thinking is correct. When painting an area where the paint has lifted, the entire area must be sanded smooth. Otherwise you will just keep making the remaing paint grow thicker, while painting the bare area. It will always continue to do just that.
Sand the area so the edges cannot be felt, it may require a good bit of sanding. Don’t sand with just a fingertip bearing down on the edges, use a pad of some sort to distribute the pressure over a wider area, that way you avoid creating an uneven trench. Make the final sanding steps with finer sand paper, so you don’t leave scratches.
Ditto. Go on You Tube and watch an auto painting video and you will see how the area in question is sanded to a feather edge that eliminates the step. This is SOP when doing spot repair painting.
Thanks, I tried with a sanding stick but couldn’t make meaningful contact. So I ordered some 800 grit sandpaper that I can cut up. Is 800 a good grit for airbrushed acrylic paint on a plastic model?
One way if you can mask off just the section or panel the bad point is on, and sand with a small piece of 1000 grit paper. Then repaint. The masking before sanding protects nearby finish. You may see panel “line” but it will be faint, and will just look like a panel.
Thanks! Will get some sandpaper and try again! Really it’s not that noticeable but I don’t like my mistakes to be passed off as intended part of the model.
It’s not really. It could be ok for a flat finish if you use light pressure and don’t dig in. Look into investing in a set of Micro Mesh sanding pads. They’ll last you a while, and they do a better job.
We all started modeling thinking that paint would work to some degree to smooth over or hide blemishes. No longer true.
Today’s paints, applied with an airbrush, can be very thin coats. If anything, a good thin coat of paint will make flaws more apparent. I’ve learned to think of my paint finish quality as a result of working at a fine finish from the inside out, not the other way around.
The 1000 grit paper does something but I wasn’t able to repaint and make the edge invisible. I ended up using thinner to remove a bigger area and am starting from bare plastic on that section. Probably made it worse but hey I tried to make it as good as I could. Bad hobby for perfectionists!
I researched and perhaps Vallejo primer is to blame for pullup so I’ll try Badger Stylnrez.
Sad that this model will never have a nice smooth paintjob but it is the Millennium Falcon. Yet another learning opportunity… resulted in learning to sand edges and to try better primer on my next one.
While I’ve not used Stylnrez primer, Tamiya’s Fine Gray primer is the best that’s out there for primers as far as I’m concerned. Goes down thin, won’t obscure detail, never had paint lift when using it. Their white primer would be my second choice. It’s in a rattle can, but you can decant it and use it in your airbrush if you want. Used it on resin and plastic with no problems.
Some guys love Badger Stylnrez and swear by it bu I second Tamiya primers. They are simply awesome. Mr. Surfacer 1000 and 1200 are also fantastic. I don’t like using acrylic primers cause they have a good chance to lift specially MM acryl primer that is simply trash.
You mentioned above you used Vallejo surface primer. That product is not sandable, so I suspect that is your problem attempting to correct the pull up. IMO, you are never going to get a perfect edge at this point. I used that product once, and had this exact thing happen to me. It has poor adhesion and doesn’t sand at all. (unless it’s had a month to cure, …maybe) It’s great for figure painters becuase it does a wonderful job of self-levelling and surface detail simply pops.
In that case, Stynylrez is really your best, if not only choice. (Yes, I know I’m repeating previously given advice).
Yes exactly… sanding is just ripping off more paint and I still have a step (with a much larger area to repaint). I will consider it a education and stop using Vallejo acrylic primer. My next Falcon will have Badger Stynlrez primer.
