Does anybody know of anyone that makes decals for the red and white safety tape used mostly in Semi trailers in 1/24th or 1/25th? I put question here because I hope to get a quicker response from you guys.
Have a look at decals meat for model railroad trains. I think Microscale makes all sorts of the type. The trick is to fins the right stripe width and pattern for what you need.
Go to Facebook and then to the MTDG. Somebody sells them on there.
Best ones I ever saw were from JBOT Decals in Canada; unfortunately, the owner had a stroke several years ago and closed the business [though I believe the site is still up for reference].
His decals were mostly printed-as-ordered, so I doubt there’s much out there on auction sites and such…but who knows, it might be worth a search.
Cheers
Not the easiest solution, but you might have to get some red and white decal sheets. Cut a strip of white to size and apply. Then short pieces of red to finish it off. Harder to get everything lined up
I worked at a Dealership. The Lady in the office that put the tabs on the plates saved me an envelope full of the left overs that just happened to be red/white reflective that year. kinda like when i asked smokers for the cig box’s to get the foil out of them.
