Recommendation Sherman Tank Kit
I am a novice/intermediate and looking for recommendations on a Sherman Tank kit as it seems like there are quiet a vew out there.
Thank you!
I’ve built a few Sherman’s, Including from Dragon, Tamiya, Italeri and Tasca/Asuka. As a starter, I would recommend a Tamiya M4A3E8 “Easy Eight”. It has pretty good detail and is an easy build - you don’t feel as if you are assembling the actual tank piece by piece as with some newer kits. Just my two cents.
Tamiya hands down. The latest Shermans from other manufacturers offer finer details, but at the cost of high parts count and fiddly assembly. But do some homework or ask around if you have a specific kit in mind, as some may be based on older kits, or like the 1/35 Firefly, are from another manufacturer (Tasca in this case).
Andrew, I agree with M1GarandFan and RealG the newer Tamiya kits are a good place to start. I would also recommend that you get familiar with this website:
https://www.scalemates.com/search.php?fkSECTION[]=Kits&q=Tamiya+sherman*
I estimate 98% of experienced armor modelers use this website for research on models they want to build. Pay attention to the release date of the model, look at the history, look for new tooling, new parts, but don’t be fooled by new box art. Many manufactures change the box art periodically, but tooling the model is made from is unchanged. Also I can’t stress this enough, read the reviews that other modelers have posted. Let the experience of other modelers guide your selection.
For example: do a Google web search for Tamiya M4A3E8 “Easy Eight” reviews. and you will find several to choose from, plus the website link above also includes good reviews.
Harold
Thank you!
The MENG WWT M4 Sherman is a fun kit lol. [Y] [Y] [Y]
But seriously, Tamiya. The new Easy Eight kit is amazing.
Thanks Harold. I was reading some of the reviews of the Tamiya kits and the words “easy” and “fun” keep coming up which is exactly what I’m looking for. Much appreciated.
Thanks Mike!
Andrew, one other important note is model scale. Sherman tanks come in 1:16, 1:35 and 1:48 scale. By far the 1:35 scale is the most popular and has the most variety offered.
Tamiya Easy 8 for sure, just make sure its the Tamiya one,not the Tamiya Tasca rebox, its a good kit too,but more involved for sure.
Hi,
As a novice builder (like me) a couple of things to look at when considering an armor build are:
  • what kind of tracks does it come with
  • does it come with add-on stuff, like photo-etch parts and/or crew figures, and
  • what is the total part count
In general there are a lot of newer kits coming out that are very detailed (some even with full or partial interiors). But as a novice that may be more than you might want to bite off, before you gain more building experience. In general many of these kits are the ones with very high parts counts and sometimes even tacks where each link has to be built up from several parts.
Other kits though may come with tracks that are molded in regular plastic where large sections (representing numberous links) end up being glued togther to make one entire track. Some people like these type tracks while others don’t. In general I kind of like them because they can give you a build with authentic looking “sag” in the tracks in the right places.
Many older kits (and some newer ones) however come with tracks molded in either vinyl or a softer plastic where you sometimes have to melt some tabs at the ends so that they form a single loop. These type tracks can be sometimes easir to deal with than others, as long as you can get them to stay as a loop, and as long as the plasttic/vinyl hasn’t gotten hard and brtlle. A drawback with them are that sometimes it can be diffificult to get them to sit right (since you are trying to bend them around spindly road wheels and axles) and they can kind of not look like they are sitting right, since the stiffness of the treads may make them “arch up” above the road wheels rather than “sag” like on a real tank.
And finally, while photo-etch can make for some nice details, there are some manufacturers which kind of seem to go overboard a bit and add photo-etch for parts that maybe don’t need to be. Since poto-etch can sometimes be a little difficult to work with, espacially when you are first just starting out, it might be worthtwhile to specifically focus on kits where it isn’t necessarily needed, for starters.
All that said, there are also alot of variation in Sherman tanks, from the earliest ones with rounded cast hulls and 75mm guns, to upgunned ones and/or oneswith angular, welded hulls and even some post WWII ones.
In general many of the Tamiya kits look like they could be a nice option.
Regards
Pat
Since you are a novice, I’d suggest some of the older Tamiya Sherman kits like the M4, M4A3 and M4A3 (105). The newer M4A3E8 kit is awesome, as is their M51 Super Sherman, but they are rather pricey and might be a better kit for when you have a few models under your belt.
Don’t discount the Academy Shermans too. Easy to build and not too expensive.
I’ll second the suggestion of the Academy Sherman’s as a back up. Also have a look at the Italeri Shermans as well. Again well engineered, easy to build, and not too expensive.
I have been building three Shermans to represent Thunderbolt V (Tamiya M4), Thunderbolt VI (combined Dragon M4A3E8 hull and turret with Italeri M4A1 VVSS suspension) to get an M4A3 (76), and Thunderbolt VII (Tamiya M4A3E8). These M4s belonged to Creighton Abrams.
The Tamiya M4 is a very pleasant kit to build. It goes together well and it looks the part, but it lacks the deck closing the sponsons to the lower hull. It is an easy fix.
The combined Dragon and Italeri kits satisfy my need to pare down my parts stash. By combining these kits, I get a satisfactory M4A3(76) for free.
The Tamiya M4A3E8 is a straightforward build that is very fun and satisfying.
There are Dragom M4 kits that are equally fun and easy with excellent detail, but be careful! Some are easy and uncomplicated, like their M4A3E8. Others are quite complex. I have their M4A1(76) W that contains over 900 parts, including photoetch. Their M4A2 is simpler with fewer parts. Also, Dragon and Italeri have sometimes combined their molds, their M4A3E8 is a case in point. I bought the Italeri version labeled “Fury”; it is the same kit as the Dragon. It was also a straightforward and fun kit to build. In general, if you want to build a Dragon kit, sty with their “Smart Kit” range at first.
Bill
Dragon’s first two Sherman kits, the M4A3E8 and M4A3(76)HVSS, kits #9009 and 9010 respectively, were basically the Italeri kit M4A2 Jumbo (kit #253) with HVSS tracks, fenders and some retooling added by Dragon.
The Italeri Jumbo kit, in turn, was their original M4A1 kit with a new upper hull and tracks added in the late 1980s.
I first bought the Italeri M4A2 in Germany around 1988 or 1989. About 5 or 6 years later, I bought the Dragon M4A3E8 kit and it was virtually the same model kit wth new tracks and suspension.
