Hello guys
I’ve been promising for a few times now that I’d post some pics of the Hueys I’m building, so here are some of the UH-1D that Ray (rotorwash) kindly sold me.
We finally got some decent weather in the UK this week, although it looks like it’s turning cold again next week, but the last couple of days have been 20 degree C scorchio’s. Personally I don’t like the hot weather but it’s been good for painting and gluing at least.
Anyway here’s the pics -
Apologies for the quality, and the flash on a few, I couldn’t get my hands on a decent proper digital camera so I had to resort to using my BlackBerry 8900.
Side view
Close up of right side
Front view
Underside
Interior
Engine
M21 weapons system
Main Rotor
Tail rotor
Inside of tail boom
Inside of fuselage (rear)
Inside of fuselage (front)
M21 weapons system detached
Some notes on the pictures -
I sprayed the fuselage with Humbrol #155 spray. Unfortunately it seems the spray paint is a slightly lighter shade to what the Humbrol #155 pot contains, and where I’ve had to touch it up shows a little. Not sure if it’s noticeable in the pics though. I also have some touching up to do on the rotor head and blades as I got a bit of red in places I didn’t want it last night.
As you can see I’ve not joined the fuselage with poly cement, I’ve instead attached magnets to the inside (and I’ve also had to put a couple of screws in the bottom). There are corresponding magnets on the inside of the other half of the fuselage which isn’t shown in the pics. I’ve done this for a specific reason - the method to my madness will become apparent in a month or two when I have bought some “special” parts…
Unfortunately this has meant here is a gap when the model is assembled. Oddly the gap is less when I don’t have the interior in, I’ve tried grinding down the side edges of the interior but it hasn’t made a difference.
I plan on trying to fill this gap using some green stuff (kneadatite) - hopefully that will at least less the gap…
Some of you may notice that there’s a bit of what looks like glue just behind the engine on the outside of the tail boom on the right hand side. That’s because it is glue. I had an accident with the superglue whilst putting in the magnets on that half of the fuselage. I’ve tried to grind off the resulting mess using a dremel but it hasn’t quite gone.
I tried to be clever with the main rotor and make it so that I can take the blades off. Unfortunately drilling of the blade holders didn’t go well and the plastic broke (as you can see in the pic). I plan on putting green stuff in this area to re-sculpt the broken bits, hopefully I can do a good enough job.
I’ve pushed out the holes in the floor of the interior for the UH-1D UN model, not realising that they weren’t applicable to the UH-1D US Army bird. I’ll fill those in using squadron. As for the paintjob on the interior, I’m not too pleased with it, I should have bought a spray can for the light grey.
I plan on repainting the engine, I’ll probably get some bronze or copper paint or something as my attempt at “weathering” is rather poor. I tried to make it look like steel with some dirt all over it, I think just a plain copper/bronze colour would look better.
Looking around the web I’m not confident of making the model look much better than it does at the moment. I’m very much a novice when it comes to painting these sort of models and even though I started painting models some 20+ years ago and though I’ve spent the last 18 years on and off painting Games Workshop models I have to say I’m nowhere near as good as I’d like to think I am at even painting GW models.
However so far apart from a few issues I’m satisfied with how this heli is turning out, considering it’s my first aircraft build in 20 years and I’m more used to working in a larger scale (GW models are 25mm scale I think).
I’ve obviously got to put the windows in (and I’ll dip those in Future (Klear for us in the UK) and I now plan on doing some shading using an ink wash from Games Workshop (there current Agraz Earthshade) as I’ve been reading up on doing that and I think I can get my head around it.
Not sure what decals to put on it but I’m very strongly leading to making this bird a “We Were Soldiers” slick (I’m getting the M60’s from Italeri hopefully, as they’ve quoted me 8 Euros for the parts), so it’ll have a number on the nose as well as a 1st Air Cav decal and 1st Air Cav decals on the tail. The M60’s will be detachable in the same way as the M21 weapon system is.
The M21 weapon system will now be going on my Revell UH-1B kit instead (I’m also going to make the quad M16’s system that comes with the Revell UH-1B kit detachable in the same way as the M21 system is).
