Hi, newbie here. I am planning to build my own spray booth and have a couple of questions.
The booth will be 24" deep x 24" high x 48" wide.
A wooden box laid on its side if you want to visualize it.
The range hood I am looking at is 18" deep x 6" high x 30" wide.
It has a built-in light too. It’s an under the cupboard type. That means you are supposed to screw the top of it up under the cupboards above a stove.
Now is it practical to install the hood inside the booth by screwing it to the inside of the top? This way I will also have to drill holes in the booth somewhere to accomodate the power cord and the ducting as I don’t want them coming out the front of the booth. It might be tricky to get the ducting to fit snug in any hole too. Is this method safe? Boxing it in like that.
My other option, I gather, is I could cut a rectangular hole in the top of the booth, say, 17 1/2" x 29" and place the hood over the rectangular hole? I would then have to figure out a way to screw it down to the top which might be tricky as there may not be any place to put the screws through the hood.
Any other ideas or suggestions?
Thanks in advance,
James [:)]
P.S. I will probably think of some more questions later.
The range hoods actually work pretty well, as long as the fan is big enough to move all of the air. When attaching, make sure to fill the seams with epoxy or silicon compound to create a good seal. The inside install would be the most practical.
For ducting, just go to your local hardware store and pick up a dryer vent and elephant trunk. With that, you could just clamp the trunk on with ring clamps and not have to worry too much about the fit.
A range hood is a canopy hood, and as such, is designed to exhaust heated water vapor that is already rising. Paint vapors are heavier than air, so mounting the range hood overhead is probably not the best way to go. It might be better to turn it on its side and place it in the back of the booth. This position would also give you a more linear air flow. Also, a word of caution: (1) Paint booth walls should be made of non-combustible materials. Wood ain’t it. (2) Any fan used for exhausting paint vapors should, at a minimum, be brushless. Remember that paint vapors are flammable, and any vapors in contact with a sparking electric motor dramatically increases the risk of fire.
Gip Winecoff
Gip brings up a good point. Are the motors in these exhaust fans brushless or at least out of the path of the air moving through them such as a squirrel-cage fan is?
I would think they would have to be since they are designed to vent grease from cooking on the stove and it is flammable, although not near as flammable as lacquer. [:D]
Thanks for the responses. I will probably mount the hood on top. It would seen the easiest way to go. Not to keen on mounting it at the back. Then the fan, and light, would be right in the line of fire of the spraying.
The Hood is not an expensive one. Only $46.99 at Canadian Tire. It’s the 30" Broan Basic Performance one. Front rocker switches for 2 speed fan and built-in covered 75 watt light.
1.7 amps,/ 120 volts. Says it draws 180 cfm and has a sound rating of 7.5 sones. (I gather that is kinda loud, but since I am single, it’s probably not to bad)
Doesn’t say what kind of fan. But for the price I am not expecting top of the line.
Will have to check for the ducting. It says it takes 3 1/4" x 10" duct for either vertical or horizontal ducting, or 7" round duct for vertical ducting.
Can anyone explain what they mean by 3 1/4 x 10? The 7" round seems self-explanatory. Is the other one rectangular metal ducting?
Either way I gather I will need about 6 to 8 feet of the stuff.
Thanks again guys.
James
P.S. Hey naplak, I am sure I have seen you somewhere before. LOL!
The 1-1/3 X 10 inch is a flat rectangular duct designed to run up inside a standard wall made with 2 X 4s.
The 7" round is pretty standar… that’s what mine is. Look for flexible aluminum pipe… it’s a lot easier to make it fit, and not much more expentive. These look about 2 feet long but stretch out to about 6 feet.
Recommended airflow for a booth spraying combustible/flammable vapors is 80-100 fpm at the face. If your booth has a face area of 8 square feet (2’ X4’), that works out to a range of about 640-800 cfm needed to adequately exhaust your paint vapors. First, (and I could be completely wrong here) , but I don’t think a fan rated at 180 cfm is going to give you adequate airflow, and secondly, mounted overhead is only going to add to your woes. Adding in pressure drop based on the length of your ductwork, you may be throwing money down the drain. On the other hand, decreasing the size of the booth, trashing the range hood idea, mounting a good fan at the bottom of the booth, thereby creating a downdraft exhaust…results in lower cfm requirements, vapors actually captured and exhausted, a safer work area, etc.etc.
Gip Winecoff
Well I don’t want to decrease the size as I have some ship kits that have 30 to 40 inch hulls to paint. So, what kind of fan would I need? I have read that bathroom fans are not appropriate. Axial? Any recommendations? Brand names, Model numbers?
And if I lose the booth I will need lighting also. Any recommendations for that? Brand names and model numbers would help as I am not a tech person. Also, don’t want to spend a fortune either.
James,
Reducing the open area on the front of a booth the size of yours, with the fan you are suggesting may only increase face velocity by a fraction, but does nothing for capturing all the vapors and transporting them through a duct. In designing ventilation systems, most engineers (which I ain’t) will add about a 25% increase in total cfm after calculating booth size, face velocity, and static pressure loss through the duct (dependent upon diameter, length, number of elbows, etc.). I would ROUGHLY estimate a fan rated at about 1,000-1,200 cfm should fit your needs. The booth you are trying to build (based on your size requirements) almost borders on, IMHO, a commercial/industrial application. I apologize for not knowing where to direct you in terms of fan types, catalog numbers,etc., but it would seem that industrial supply businesses should know about, or have access to the products you need. You may also find it cheaper in the long run (if liabilities and insurance considerations are an issue based on renting or owning ) to purchase a booth, rather than build one. Pre-built booths will–or should–have all the features you want, plus they should carry some sort of approval or certification so you can paint away knowing your pride and joy won’t catch fire in the middle of a measure 32 paint scheme. Depending on the booth, they may also come with the right filters and baffles, which will distribute airflow evenly throughout the booth so there won’t be any dead spots when you’re painting. For me this has become quite an interesting thread. Please keep us informed as to what you decide to do, and what results you finally come up with.
All the best,
Gip Winecoff
Thanks again! Well, I looked around a bit on-line today, and the fans (explosion proof, brushless, high CFM,…) I could find that match what is required were huge (and expensive). I think some were designed to go on the roof of a nuclear reactor. LOL!
Unless I am not looking in the right places.
Question - Do I have to vent the booth? Or can I vent the room instead? I am thinking that the appropriate fans are probably to large for the booth I have in mind. Is it feasible to put a large exhaust fan in the window of my separate modelling room?
I don’t think an airbrush, for the amout of spraying I will be doing, would generate that much fumes anyway, so…
This is all a tough choice. Any type of ventilation is better than none. And the more the airflow, the better. I tend to use enamels and lacquers, so I’m after as much airflow as I can get. Direct ventilation to the outside would always be my preference and is probalby cheaper/easier than trying to vent an entire room. I had a small booth with 3 seperate 80cfm fans in it. I thought it would be plenty of power, but I didn’t like it. You have to remember that the type of ducting and all of the corners and filters really consume alot of the ‘cfm’. I don’t remember all of the detailed calculations, but the reality is that if you’ve got a 200cfm fan with a flexible vent hose and a filter attached, chances are that the final cfm at the front of the booth isn’t a whole lot better than about 40-50cfm. If you can, use a solid sheet metal vent with as few turns/corners in it as possible. It might cost a bit more, but the end result is much better.
To each his own (health risk that is…), but I have a new fan that’s something like 380cfm for a relatively small booth. I’m hoping that it will be enough once I get everything set up, and plan to have as little air resistance as possible for getting those fumes out of my house! Getting 1000cfm is a pretty tall order, but technically is what would do the best job at venting a booth the size you’re talking about. You have to make your own choices, but personally I would try to get more air movement than what a range hood is going to give you.
I know. A 1000 cfm does seem rather unattainable in reality for the size of booth I want. You would be building the booth “out of” fans. It is also cost prohibitive. At least for me.
What do most people, that have airbrushes, do? And as we all know, there are thousands of them. I can’t see most of those people with large expensive ventilation systems.
I gather most just do what they can afford and hope for the best.
You are right that a ‘perfect’ booth is probably not as common as a simple cheap set up. However, ANY ventilation is better than NO ventilation, so whatever you can do will help. My last booth had 3 muffin fans in it (all in a row). It actually worked fairly good, but it didn’t clear the fumes as much as I wanted, especially when I was using a spray can. For airbrush use alone, it worked pretty good.
As for the whole ‘explosion risk’ issue… well that is a reality. You need to make your own choice about that.
My advice would be to get the fan that has the largest cfm you can afford, and then build your booth around that. You already know it’s not going to be what the ‘industrial guidelines’ would call for, so get as close as you can.
James,
You know, ventiing the room may be a viable option. Factoring in the frequency and duration of your painting along with the volume (which isn’t a whole lot with an airbrush), a large exhaust fan in the window, and maybe a small fan behind you when you spray would provide enough dilution ventilation to reduce any potential health hazards associated with spray painting. I didn’t tell you this, but I don’t use a spray booth. I simply open a window and room door, and turn on my ceiling fan. While this in not ideal, it still works. I am only using about 2/3 of a color cup full of paint for most of my 1/35 armor. Priming, base coat, and running a little thinner through the brush for final cleaning leaves a slight to moderate odor in the room that quickly dissipates. By the way, smelling a solvent doesn’t necessarily equate to overexposure. Many solvents have an odor threshold at several ppm, while exposures occur at 10 times that amount (speaking VERY GENERALLY).
You could also, if desired, spend $20 and get a good respirator to go with that window unit. Going this way will probably save you several hundred or more dollars when all is said and done and still offer the protection and safety you’re looking for.
I apologize for not thinking of this sooner, and any appearances of hypocrisy on my part. You mentioned spray booth, and that is all I focused on. Keep us posted on your decisions and outcomes.
Gip Winecoff
Yes on the respirator! Good call Gip! I missed that too. I don’t often use mine when I’m just airbrushing because the booth does a decent job of clearing the air. However, whenever I get a rattle can out, I always put on the respirator. And, I open the room window as well (unless it’s winter…).
Keep us posted on what you go with James! The fact that you’re aware that you need ventilation is a good thing. Gip’s got good advice and ideas.
If you use acrylics exclusively this problem will be easy to solve, but if you are using enamels or lacquers it will be more difficult as has been discussed already.
