Quiet Air Compressor with accessories Model: FP2040
has anyone used or bought this compressor…just puchased it from wal-mart and intended to use it for airbrushing. I has a regulator and I purchased the mfg’s filter/moisture trap along with a quick disconnect for the hose/compressor connection…just thought that I would ask about it prior to using it…I am including a link to the page where the stats can be found in case someone wanted to comment.
http://www.chpower.com/chimages/catalog/active/comp_FP2040_150x120.gif
That is the compressor that has been mentioned before on this forum as well as talked about quite a bit over at the airbrush forum I frequent.
It has mixed reviews but most people I have heard from say to avoid it as it overheats and dies an early death. There have been a few people who have had fairly good luck with them though so hopefully you are one of those. [;)]
Too bad you couldn’t have gotten one of those cheap $39 Whisper Jet II airbrush compressors that MikeV found at Ebay before the seller pulled all, what, 50 of them?
Good luck on your purchase.
Well…the way I figure it, I should be able to get my 60 bucks out of it for the time it does last. Not to mention that they do have a 1 year warranty and I will collect on that if the thing goes down hill. I will use it and get me a better one after the kid is born. It should hold up till then. Thanks for the info guys!
Warrior1973,
Just return it every 11 months. [:D] [;)]
I have that compressor and so far so good. It hasnt overheated yet and is working very well with my Badger 150 and Crescendo airbrushes.
Regards, Dan
Hook it up to a great, big tank (like an old water heater!). Pump it up and then paint from the tank for a week or two!
