About to start building the T-90 and realize that this has some very prominent parts molded in clear plastic.
The T-90 has everything from the drivers hatch through to varioues periscopes and some really big stuff looking like Cameras mounted on the turret.
I paint them all. To me, the clear periscopes and such are a gimmick. They do not look like actual periscopes if left clear. On most modern vehicles, the optics appear red/gold/purple since they are coated with anti-laser tint anyways. On older (non-coated) optics, they look like dark slits with a green tint as well, not clear. Painting them as opposed to leaving them clear looks more realistic to me.
I install the optic, then paint over them with the hull color. I then start by painting them black. If non anti-laser coated, I will then apply a couple coats of clear green, followed by a couple coats of clear gloss. For anti-laser coated optics, I cover the black with a couple coats of clear red (for US red anti-laser) and then a couple coats of the clear gloss as well. This method works for me.
This one has the optics around the commanders’ cupola done as non anti-laser coated in the green tint.
First off, that is not a T-90, but a BMPT “Terminator” which is an armored fire support vehicle built on a T-72 chassis. It is designed to support tanks, APCs, and infantry in urban areas.
I agree with Phil as well. I prefer paint over colored films and such.
I am about to enter with the Terminator in the Modern Armor Group build.
The problem is the same though, the optics are very prominent.
Here is the T-90. Here you have the added complexity of the two infrared jammers of the Shtora-1 (Штора or “curtain”) system.
These are sometimes depicted in glowing red, do’t think that is correct though.
Anyway, I will elaborate with your suggestion for the periscopes, this will allow me to speed up the assmebly significantly, and play arround with Phil’s suggestion s well.
By the way, the Zvezda kit shares a lot of components between the T-90 and the BMPT-72. Lower hull is identical. Which means hat the BMPT-72 has the same problem with the stance the kit beeing to high.
Thank you for taking interest and time to comment.
Very much appreciated!
The same technique for the optics can be used on larger optics as well. Here it is on the ISU of an M7A3 Bradley.
On the T-90, when the Shtora-1 system is turned on, they do glow red.
The T-90 is also built on a T-72 chassis. It is really just an upgraded/modernized T-72B that the Soviets/Russians (developed under Soviet rule, fielded after Soviet Union fell in Dec '91) renamed to make the west think it was an all-new tank. That is why it has common parts w/the Zvezda T-72.
