Is the muzzlebreak on the new tamiya kit accurate ? I just got a Jordi barrel and the break is different ( I put little faith in jordi rubio being accurate)
I noticed the same thing on the one I am building right now. The one on the Jordi barrel is alot smaller than the Tamiya version. You also have to figure out the right placement for the Jordi one since it has no tab like the Tamiya one. As far as accuracy, I have no clue. But it may as well be on mine since it is glued nice and tight.
I just checked two different sources, and for 1/35th scale, the muzzle break should be about 14mm X 9mm. I checked my Tamiya Marder III with the 7.62 Pak 36, and the dimensions appear to be correct for that kit.
hope this helps[:D]
TY edog , I just noticed a different shape on the 2 barrels , however I did notice on the different pix I had of the real gun , there were some of each style of MB on the guns , so maybe its just another case of right if you use either ?!
