Question about my "new" Badger airbrush
OK, so I bought a Badger 150LG airbrush on Ebay. I know the actual airbrush (not the model) is old. I’m guessing the actual airbrush was made in the '90s. I was cleaning it today when I noticed the inside of the airbrush was very rough. In fact, whenever I ran a swab around the inside, little pieces of cotton were being ripped off. I’ve had other Badger airbrushes and I don’t remember having this problem. It’s like the inside of the airbrush is unfinished. Has anyone else seen an issue like this before?
-Jesse
No. Sounds liike you got an old worn out airbrush. I would try to return it to the seller.
If it was worn out, the burrs would be worn smooth. [:D]
If you’re talking about inside the body of the brush, there’s several spots you may find a burr. It doesn’t take much to pull apart a swab or QTip, they’ll grab on anything. Even the finish on the inside of the cup will grab fibers out of a QTip. I have several different gravity feed Badgers and there’s at least one spot in the cup of each brush that will. So, I don’t use QTips or swabs. I bought a large, flat brush with a rounded tip to clean the cup, some interdental brushes to clean the passages at the front of the brush and a set of cheap bristle brushes at Harbor Freight for everything else that needs cleaning from time to time.
Tony
