i recently sprayed the inside of my tiger I interior with a mix i made with some white in it. not until it dried did i realize that the white i mixed in was regular white and not flat white, so its semi glossy. i have some MM acryl flat clear. is it possible to brush this stuff on, or do i need to airbrush it on to get rid of that satin apperence?
It sure can. It’ll brush a milky white color but dries clear. Avoid overbrushing as it will leave marks. Use a wide, very soft brush. Also, apply a very thin coat. A lot of Acryl flat goes a long way.
-Jesse
so should i thin it? or can i use it straight, just cautiously and thin? and to make sure i understand it, it will dry FLAT clear right? not satin.
well are you planning on showing your interior off? If not then don’t worry about it, but if you are, I’d Airbrush it to avoid ANY forms of brush strokes! If you brush it, you might aswell have brushed the white paint on too! Flat paints tend to show brush strokes in the worst way, and in my experience, airbrushing flat coats makes it look better and ensures proper coverage.
