Q about Silver paint....Grrrrrrr!!!
Ok, It seems that every time I use [Testors] silver paint I run into a problem with it even after it’s sat for 3 days in a warm area. Seems the paint rubs off onto my fingers & I masked it off to shoot another color(Using the Blue 3M masking tape which I stuck to my skin first) and I’d have streaks in the siler paint where the tape “lifted” it leaving behind some residue.
This isn’t the first time it’s happened. I’ll post some pics if they come out right.
TIA,
Eddie
Edit: Here’s the pics
This is an enamel, I’m assuming.
It is possible that the pigment load is too high, due to evaporation from the original container. But it is more likely due to settling in your paint cup or “spraying dry.” It sounds like the surface of the paint is “dusting.” You would notice this effect immediately with an ordinary flat or especially a gloss paint—but metallic pigments are different in that they are flat particles, so they tend to lie flat on the surface, producing a normal appearance until you touch it.
Aggitate the paint in the airbrush cup, and use a slow evaporating solvent, or slightly more of it, as a reducer. Move the air brush a little closer to the surface, too.
Yes, it’s enamel paint which I mix pretty thoroughly in the paint cup to a consistency of 2% milk & add a couple more drops & stir it. So, I should add a little more thinner to it? I’m spraying at 15psi and at approx. 3" from the target area. As you know, I’m using the Badger 175.
I’d drop your air pressure, first.
What are you using for thinner?
I’m using Testors A/B thinner and my gauge is set at 15psi but, it drops down to about 10-12 while in use.
This is a base for 1 of the 1/2500 Star Trek Enterprise sets I’m working on & I did the sides of the emblem in a flat Black. I need to wet sand it a bit & shoot it once more before I go trying the Silver again. Why have to redo the silver when i can still mask off this coat?
Any idea what the solvent(s) is(are) in the Testors thinner?
Try straight odorless mineral spirits and see if you get a better result.
I have no idea. I do know that I’m just about out of the stuff… I have a big can of Thinner I had picked up at Home Depot Blue & white can (Klean Strip) Paint Thinner made with Mineral Spirits. [Thins oil-based paints, stains & Varnish] I’ve used this thru a HVLP while painting a house. WIll try it & see how that works with the silver
Ed, I dont know what the solvent base is in Testors THINNER is either. But I do know Testors Silver#1146 has always had that problem (seal it with a clear prior too) Testors also has the Metalizer Lacquers in silver tints that should be sealed with their own sealer or equiv.? There is also Testors # 2734 Silver Chrome and MM # 2714 German Silver Metallic Enamel that you might want to try? Seal it is my best guess. HTH
From what Gulfstream V is saying, it sounds like they formulated it to have a very high pigment load—one way to get a very “metallic” look to the surface. As he says, sealing it may be the best fix for the problem.
I Concur Ross.
Hmmm, Now all this time I thought it was me with the problem!![swg] and to learn Testors did this on purpose.[|(] Ok, Looks like I’ll throw down the paint , let it set & shoot 'er with Future. Think that’ll do the trick? Or, do I go ahead & try this stuff I got in a rattle can called “Crystal Clear Glaze” (by Krylon) says it works on plastics,paper, wood, metal…
Go for the Krylon! Ed, If it dosen’t work? Oh Well? DOT 3 is an option. And Dubau/Bud Sig is what we all have been thru. Good Luck Bro!
Thanks GSV[tup] It’ll be a few days before I go repainting the silver but, I’ve got the DOT 3 at the ready… I’ve had this problem once before & before I had a chance to get back to it, daily life stepped in. Now that I have more “freetime” I’m back to my models.
Hey Bro, you been using the Testors 1/4 oz 1146? Chuck it in the trash, or save it for touch ups. For major spraying, next time use their 3 oz rattle can 1246. For some reason the spray can gives much better results and don’t worry about your AB getting jealous. I found that the older those 1/4 oz bottles get, the nastier they are to dry. Also the metalics such as silver and gold don’t appreciate being thinned.
Clue for Ross… maybe? The silver paint tends to act with age like it hand linseed oil added to it. You know how old timers used to add some linseed oil to enamel paint to retard the drying time. Add just a bit too much and you end up with a gooey never to dry sticky layer of… well you get the idea.
I’m not so sure I would want to shoot a coat of clear over a non-cured layer of paint. Ed, have you tried putting it close to a non-flammable heat source for maybe a few days? If the silver coat can smudge now and you paint over it, it will always be smudgeable (I know, not a real word LOL). [:P]
Hey Jim, Haven’t seen ya around lately! Dang glad ta see ya!! Hmmm, so, this stuff don’t have much of a shelf life huh? That’s interesting to learn. I guess I could see if they have hte rattle can at Michael’s next time I get up that way.
I’m in no rush on this & as for a non flammable heat source, I don’t have anything around here.
Thanks for the run down.
Eddie
I’ve been super busy with college. Just finished finals for this semester, pulled off A’s & a B+. Next semester doesn’t start until 1/8/07 so I get a big break. [B)] Well kind of, been working on the online shop and well, going nuttier.
It’s hard to tell exactly how long those little bottles have been sitting on a shelf even before you get them. Also the metalics like to be stirred and shaken constantly as the pigments settle quickly. You’ll have to constantly shake the can while spraying, but it comes out nice.
Duh… [:I] It is a lot warmer where you are compared to where I am. So maybe just letting the model sit for a few days might help??
If you have a Wally World near you, they usually carry that color too.
I haven’t used Testor’s enamels for years, but now that Jim mentions it, I do recall that there was a drying oil in their metallics at one time.
This can also lead to problems with shelf life if there is a small loss of solvent. That’s when the retarding effect (not true retardation) of the oil can cause havoc. I still also suspect a high pigment load.
Metallics generally have a lower shelf life than other paints, regardless of system, because of the oddities of the pigment, and the problems with formulation that makes necessary.
Rattle cans of metallic have a very definite shelf life (buy only as much as you will use on one project!) but it is usually very easy to tell when they have gone “off.”
Off topic: Congratulations on your success in college, Jim! Glad to hear it![tup]
I’m not sure what the difference in carriers are between the metallics and regular enamels, but you can see a difference when the pigments settle out.
Regarding the shelf life - I have had some bottles now for two years that I am still using for brushing small items. They are starting to show the need for replacement as it is taking longer to dry (overnight and the next day). The cans I sometimes buy 2 at a time, 1 for the current project and 1 for the next. The longest I’ve had an un-used can on the shelf is about a year and it worked just fine. Used cans I use up rather quickly so I don’t know how long they can sit around for.
Just a few more words for thought, or ramblings on… [:-^]
Off topic: Thank you Ross! [:D]
It seems that this was a good topic for discussion[:)] Seems I am learning something from you guys about paint!! Now would the Aluminum paint react the same as the silver or is that a different formula?
Oh, and Jim, Congrats on the college stuff. I know you’ve been workin’ & studyin’ hard there my friend[^][:D]
