This is probably the dumbest airbrush question there is, But, If you change from a medium needle to a fine needle, do you also have to change the tip and regulator? Please go easy on my ignorance
Thanks
Thanks
I would think so. At least all the brushes with changeable needles that I have seen (or seen their parts lists) have have different tips for different needles.
I agree with ABARNE. I’m only familiar with Badger brushes, but all of them that I’ve seen or used are the same way. If you swap the needle you will need a matching nozzle and possibly spray regulator.
Yeah, my Pasche airbursh has a fine, medium and large needle and tips to go with them. The diameters for the needles tend to be what is different and you need matching tips if you want things to adjust properly.
That’s what I figured, Thanks alot guys
