Should I be priming my resin figures with Mr. Surfacer 1200, now that I got my airbrush working? What would be the ratio if I thinned with alcohol, if that’s what I should thin with? SteveM
Do not thin the Mr. Surfacer with alcohol. You should thin it with Mr. Leveling Thinner. I recommend getting the Mr. Surfacer in a spray can for Priming. Citadel primer and Tamiya primer are also very good.
Cheers
Rob
Agreed. Citadel or GW white or grey primer will be fine. I recently got a can of MR. Surfacer 1200 spray and I am in love with it. Otherwise I hve used light coats of Duplicolor grey sandable primer (mainly for resin!)
