Well, I finally got around to setting up the primer test. I decided to test out three brands:
- Vallejo Acrylic Polyurethane
- Badger Stynylrez
- AK Interactive Waterborne polymer
No particular order to it. My main reason for this is am wanting a primer that is acrylic that I can sand. I have used the Vallejo in the past and it works very well as a base coat, but I cannot sand it. It comes off in chunks. Now to be fair I can polish it with a very fine grit paper but that is not what I am looking for out of a primer. I want to be able to spray, inspect seams and the like, and then repair. I have used Tamiya’s fine grey rattle can and it is wonderful, but I don’t like the cans and I don’t like the lacquer smell plus the overspray is messy and want to spray indoors.
So before I get to the first part of the test, I am not going to say one is good and one is bad, I just wanted to see what I find. OK, I took a plain piece of card styrene and wiped it down with Testors Polly-S plastic prep:
Obviously this is from my abstract period in painting:) I wanted to make sure I had something for the primer to cover. I then sprayed the three on the divided section of the card:
The AK is on the top (I have the grey), the Badger is in the middle (I have black), and the Vallejo is on the bottom (I have grey but it really comes out almost white). You can see that all covered just fine. I used a good solid coating that I built up with many passes in light coats. I used it straight out of the bottle with a .5mm needle in a Badger Patriot at 25 psi about 6 to 8 inches away.
All of them spray just fine with that configuration and gave the airbrush no trouble. The Vallejo has the most odor which is kind of sweet. The AK has a faint distinct odor that you have to get real close to, and the Badger had hardly any. All cleaned up with plain water and some Testors acrylic airbrush cleaner. The AK seemed to be the thinest out of the bottle and reminded me the most like actual acrylic paint. The Vallejo was a bit “rubbery” and was the most difficult to clean. the Badger was the thickest but cleaned very well.
So for part 1, none seems to be “better” than the other. I amgoing to let the card sit for 72 hours. I am in Arizona and the current humidity is around 20% tops in the afternoons. The house may be a little less. I think 72 hours should be more than enough time to make the surface ready for sanding. I am looking forward to the results.
John
