Are there finer scale pressure regulators out there that you can put in line after your other regulator? Like, my regulator can dial up psi from 0-200, but the increments are coarse, by 5 or 10 psi. A/B’s are only good at roughly 10-30 psi range. How do you dial in these accurately? I know, double action A/B’s can be regulated finely by touch, but that takes practice. I’m new to using my '360 and never had an A/B before. I tend to jump into new stuff with both feet, smart or not. Thanks, SR
Are you talking about a regulator on the air compressor that needs finer adjustments? If so then yes you could buy another inexpensive regulator with a finer scale of adjustments.
That is not true. Any airbrush regardless of single or double-action puts out the pressure that you dial in the compressor or regulator. You do not push down slightly on the trigger to get a little less air as that is not possible. On every airbrush you always push the trigger down all the way for air. If the pressure is too high you turn it down with the regulator that the airbrush is connected to.
Mike, I hope that you realize that on most Aztek double action airbrushes, you CAN regulate air flow with the “downwards” button push. It’s not an ON/OFF thing with the air.
Vinnie,
I was referring to regular double-action airbrushes which also are not “on or off” but pushing down part way is extremely hard to do and I know of no one who does that as it is not necessary and is almost inpossible to replicate. I don’t know how the Aztek’s trigger works as I have never used one.
oh, thanks. MikeV, yeah, I meant a finer adjustment kind of pressure regulator. I’ll look around for that. I think I need more practice with my A/B, but really haven’t had the time; why won’t the people at work understand this?! ha.
I’ve been using an airbrush for over 20 years and I never needed a finer regulator than what normally goes on an AB compressor. Yes, my regulator reads in 5 lbs markings and I can dial roughly more or less than that. But are you saying you need adjustments of one or two lbs? For example you need 23 lbs. instead of 22 lbs of air pressure? That small increment wouldn’t make a visible difference. If one lb. of air pressure did make a difference you know all the regulator companies would be hawking a more expensive regulator. And that regulator would be a “better regulator with a bigger and finer adjusting gauge that will spray so perfectly you’ll be spraying perfect whisps of color.”
I’d use the standard regulator and just dial a close number of lbs. of air that works in your air brush.
I have a Paasche regulator that reads and adjusts in individual pounds… it is very accurate! I got it from Dixie Arts. [:D]
http://www.dixieart.com/Dixie_Art_Supplies_Airbrush_Main_Page.html
ShamRage,
The point made by Roosterfish is a good one but I would opt for a regulator/moisture trap near your airbrush such as the one that Naplak mentioned anyhow if you don’t have a water trap already.
If it is an exposed gauge that you can get to you can also just buy another gauge with lower increments if you want that fine of adjustments, although I don’t think a couple of pounds of air pressure is going to make much difference as Roosterfish pointed out.
ok … thanks. like i said, maybe i just need more practice.
here is a gauge that is 0-30. i have one of these stores nearby but you can get anything you need through the mail. i bought all of the items i needed here to build my silent compressor with. browse this site for other gauges as well. http://www.grainger.com/Grainger/productdetail.jsp?xi=xi&ItemId=1611663913&ccitem=
cool. thanks alot.
